07-02-2011
My Catalina 25 isn't plumbed that way. Just a single Y-valve, like you've always seen.
I take it that the hose from the deck pump-out fitting doesn't go directly to the holding tank but instead through this Three-Way valve. Seems like that Third Position is meant to isolate the head from the suction of the pump-out pump.
So, applying vacuum to the deck fitting, with the Valve in the head-to-holding-tank position doesn't do anything?
If that's the case, well, zip ties are sold by the bundle...
Joe - Catalina 25
