07-04-2011
Senior Moment Member
It depends on how much water you have to move. I have a cheap plastic "Navy" pump - like the defender design - that I use for slurping up a few gallons here & there into a bucket. It has worked well for several years now.
For larger volumes and for a portable emergency pump I mounted a Whale gusher 25 double action aluminium pump on a board with a handhold cut in it. I made up a 4' stainless tubing handle so it can be pumped standing up on the board which holds everything in place. If you put well thought out hoses on it you can move it to where you need it, stand on it and pump very easily due to the long -"stand up" handle.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
