Old 07-04-2011
thevdeub is on a distinguished road
Custom O-Ring ?
My Deck Fill are too small and i am looking for a thick polymer/strng plastic O-Ring to adapt, something around 3-1/2 diameter, 1/2 thick. i have been looking in every hardware store in the area looking for something i could use without any luck.
any idea where i can get custom work done for small pieces like this in small numbers (3-4) ?
Old 07-04-2011
speciald's Avatar
Special Delivery
speciald is on a distinguished road
Send a message via Skype™ to speciald
There is a shop in Jacksonville Florida called "Everything in Rubber" - Hecht Rubber Corporation, Industrial, Rubber, Products, Engineering, Fabrication, Manufacturing, Jacksonville, Florida - Hecht Rubber Company - That may be able help you.
Old 07-04-2011
speciald's Avatar
Special Delivery
Old 07-04-2011
DwayneSpeer's Avatar
Old Fart
DwayneSpeer is on a distinguished road
Tacoma Screw
You might try Tacoma Screw. They have just about every size o ring that you could imagine. Call them at (800) 562-8192.
Hey, can one of you guys pass me a crab?
Old 07-04-2011
Irrationally Exuberant
arf145 is on a distinguished road
Or McMaster-Carr
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 07-05-2011
hellosailor's Avatar
McMaster or Grainger and if they don't have it, contact Loctite or Permatex, they both sell/sold custom o-ring kits. Yards of butyl tubing with a special adhesive and cutting jig, so you can make up any o-ring you want.
You can also do a failry good job by taking a foot or two of black plastic tubing, or black vacuum tubing, or clear tygon tubing, forming it into a circle, splicing the ends on a 45-degree diagonal (not just butting them up) and then using a good glue to seal them. O-ring glue, or one of the crazy-glue variants that says it is OK for use on flexible surfaces.
If you do it that way, buy enough to make 2-3 and practice first.
Prop Ring kbmab Pearson 2 11-10-2010 04:42 PM
ring around the anchor mwil203434 Cruising & Liveaboard Forum 3 12-16-2008 05:14 AM
Tube, ring and line Giulietta General Discussion (sailing related) 42 10-18-2008 07:03 PM
J22 spinnaker ring height on mast? KRCSWO General Discussion (sailing related) 1 04-21-2008 07:17 PM
looking for Captains Ring TC2 General Discussion (sailing related) 2 07-13-2006 11:04 PM
