Old 07-07-2011
LakePirate's Avatar
LakePirate is on a distinguished road
How does a Honda Generator work?
I'm not really questioning how it works, but more of if it has a generator of some sort that can produce 2000 watts of power off a small gas engine why has someone not figured out a way to make a similar generator that can be attached to the existing motor already in the boat? Is there something to how it works I don't understand. Remember, I'm not an electrician or an engineer.
When a Woman says - Go Ahead: This is a dare, not permission. Don't Do It!
Old 07-07-2011
PaulfromNWOnt's Avatar
PaulfromNWOnt is on a distinguished road
You can attach a generator to the existing motor. Logistics is the likely answer. The engine in your boat will typically consume far more fuel for a given time than the little honda, plus you'll have to increase the size of the engine compartment to fit the extra hardware. Your engine will already have an alternator that is used to charge the batteries, and that can be replaced with a larger capacity unit which can then be used in conjunction with your battery bank and inverter to produce 110AC.
Commercially available generator systems tend to be less problematic than something cobbled together (as well as cheaper), but there is really nothing stopping you from doing things differently.
Old 07-07-2011
epaolino's Avatar
Rapscallion
epaolino is on a distinguished road
The Honda EU2000I has a motor that turns an alternator to produce 12vdc and feeds that into an inverter to create 110vac. The main feature is that the electrical load affects the speed of the gas engine. Also the alternator is sized and geared to the engine.
If you were to hook up an inverter to your electrical system the alternator will not produce enough power at idle. You whould have to bump up the engine speed to a point that you will be wasting a lot of fuel. But if you are not concerned about the fuel economy and the noise of running the engine and you are willing to manually adjust the engine speed to the electrical load it can be done! Also a large battery between the alternator and the inverter helps.
Old 07-07-2011
goboatingnow is on a distinguished road
yes its been done many times, see Balmar etc, then all you need is an external invertor and for $1000s more you have the same system.
Dave
Old 07-07-2011
LakePirate's Avatar
The way I understand it is a high out put altenator and a say 450 hr battery bank with a 2000 watt inverter would still not do what a honda ue2000i will do. It seems like what ever is inside the honda could be put on an inboard motor and do the same as the little honda unit. But thats just my thinking. I would like to see inside the honda.
Old 07-07-2011
Minnewaska will become famous soon enough
As you've read, it can be done. Here's the simple answer you asked for. My motor burns 2 gallons per hour, my 8kw onboard gen burns 0.75 gallons per hour.
p.s. My Honda 1kw gen burns something like 0.1 gallons per hour.
Jeanneau 54DS
Old 07-07-2011
GaryHLucas is on a distinguished road
The guy who writes about this stuff for sail magazine once did a comparison chart of cost per kilowatt hour for various sources with amortization of the total costs. The outlet at your marina is like 25 cents per KWH. Solar and Wind is a whole lot more, your main engine can run $5.00 per KWH! The hands down winner for low cost per KWH was the little Honda inverter generators!
I got curious and did a little research on the life span of those things. I found an interesting website by a guy who had been living in a house far off the grid using portable generators for power with batteries and inverters for night time use. He was getting about 1000 hours out of number of different brands before they required too much repairs to be worth rebuilding, and he was religious about proper maintenance. Then he bought one of the little Honda units, for about twice the price. After 5000 hours of really low noise operation he realized they were a bargain!
I was in a rental place one day and they had a long row of portable generators sitting there. I asked the guy if they had ever tried one of the Honda inverter generators. He said a salesman came in, but they were much to expensive. I explained to him that the typical rental generator gets taken to jobsite where it sits and runs at full speed for 8 to 10 hours a day, burning a lot of gas, making a lot of noise, wearing it self out, waiting for someone to pull the trigger on a saw or drill for a few seconds maybe 100 times a day. The Honda would sit there idling away, using little fuel, making little noise, and wearing very little. It would speed up as soon as the load was applied. I'll bet the contractors would love the low noise and small fuel use, and would even pay a little more for the Honda. So it is very likely it will last way longer in that service, easily justifying the premium price.
Old 07-08-2011
MSter's Avatar
Salty
MSter is on a distinguished road
In addition to less fuel consumption, engine hours are also important to me in terms of maintenance. In comparison, the Honda is pennies to dollars cheaper any way you slice it.
One could also argue the Honda is much quieter and does not introduce cabin heat as it is physically outside the cabin.
So, while you could adapt your engine to generate AC...why would you want to?
MSter
1979 Irwin Citation 39
Dragonfly II
Honda Generator not triggering charger boltnbrew Gear & Maintenance 19 03-16-2012 02:19 PM
Help Please Honda 3000, or Yahama gas generator Popeyensweetp Electrical Systems 0 03-21-2009 04:23 PM
Help costing a generator and lots of generator questions... labatt Gear & Maintenance 10 10-16-2008 01:01 AM
Honda Generator Gas Conversion EuphoriaOz Gear & Maintenance 2 02-09-2008 07:20 AM
Honda EU2000i Generator - Life expectancy GeorgeIP350 General Discussion (sailing related) 1 09-11-2006 11:33 PM
