Hull Cleaner recommendations - SailNet Community
post #1 of 8 Old 07-08-2011 Thread Starter
Seabrite has two biodegradable cleaners: one with urea hydrochloride and another with oxalic acid. Can anyone recommend which one works better for removing hull stains? (I'm trying to avoid using On/Off for now.) Thanks.
JackTar6 is offline
post #2 of 8 Old 07-08-2011
Skipper Jer's Avatar
I used toilet bowl cleaner when I had my boat in the Indian river down in Melbourne Florida. The toilet bowl cleaner is thick so it sticks to the hull. If you try this do a small spot first. Don't leave the gel on the hull for an extended period of time, maybe start with 30 second exposure time.
Skipper Jer is offline
post #3 of 8 Old 07-08-2011
Senior Pirate
TropicCat's Avatar
Where did you keep the boat when you were here in Melbourne, FL?
Tropic Cat
TropicCat is offline
post #4 of 8 Old 07-08-2011
At first we kept the boat at Diamond 99 marina. Later we kept her on a mooring in Malabar.
post #5 of 8 Old 07-08-2011
Senior Pirate
TropicCat's Avatar
You should remember my boat.
Tropic Cat
post #6 of 8 Old 07-08-2011
pinayreefer's Avatar
My boat is still in the water and some of those cleaners seem pretty nasty. Are you looking at biodegradable cleaners because you are in the water also? Are the biodegradables suitable for using where the rinse is going in the water body?
pinayreefer is offline
post #7 of 8 Old 07-08-2011 Thread Starter
Actually, the rinse is running down my driveway and into the yard (boat is on a trailer). That's why I want biodegradable. I wouldn't use it on the water although they advertise you can. Regular soap and SOS pads have not fully worked, so I need to escalate. I think toilet bowl cleaner may actually be more toxic.
JackTar6 is offline
post #8 of 8 Old 07-08-2011
DrB
Depending upon How Bad
the stains are, you could try SoftScrub. Works well on gelcoat and won't scratch it. I use it to clean "stained" areas of my gel coat, then wax the boat. DO NOT use on Awlgrip.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
Ever wonder what your hull cleaner is doing down there? Fstbttms Gear & Maintenance 30 06-20-2011 03:28 AM
recommendations on cleaner RocktheBoat Diesel 7 07-06-2009 02:48 PM
Diesel fuel tank cleaner recommendations? BELLATRIX1965 Gear & Maintenance 1 03-29-2009 06:51 PM
waxing hull recommendations? Loualfr Gear & Maintenance 10 02-27-2009 10:11 AM
Hull Cleaner bmelchionda Gear & Maintenance 2 05-25-2007 07:47 AM
