Old 07-09-2011
weinie is on a distinguished road
help replacing forestay chainplate/anchor roller...
I have a catalina 27 with a headsail furler. I want to replace an anchor roller that has been all bent out of shape by a previous owner. I have found the exact replacement online but I am worried about the installation.
If I remove the forestay from the chain plate, can I reattach it with ease or is it under too much tension?
Is this a one man job?
Old 07-09-2011
sawingknots's Avatar
sawingknots is on a distinguished road
you will need to loosen the back stay as much as the adjuster will allow,you may also need to tie off using a haliyard to the bow area,yes one man job
Old 07-10-2011
Will my mast fall over?!?!?!
I don't have a jib halyard. Do you think the main halyard would work to put enough tension even though it would be twisted half way around the mast to reach the bow and not pulling directly ahead?
Old 07-10-2011
deniseO30's Avatar
Lies about her age
The main halyard will work too. After you loosen the back stay. Cleat or tie the sail shackle to the mast and tie tail end forward with a truckers hitch so it will be tight. The head stay should be real loose then. Good luck!
Old 07-10-2011
mitiempo's Avatar
If there is a sail on the furler there is a halyard holding it up.
Brian
Old 07-10-2011
good point!
Forestay adjustment with Hood drum roller furler Nilaya Gear & Maintenance 7 06-07-2011 04:55 PM
Replacing broken roller furler Jaggma Gear & Maintenance 5 09-12-2009 04:48 PM
Replacing forestay...? marinesniper Gear & Maintenance 14 12-03-2007 09:32 AM
How to tension forestay with roller reefing? wysiwyg Gear & Maintenance 17 06-14-2007 12:09 PM
Replacing Roller Furling asailor Gear & Maintenance 12 10-16-2002 07:14 AM
