Old 07-11-2011
brokesailor's Avatar
SV Skalliwag #141
brokesailor is on a distinguished road
Barlow 15 winch maintenance
I can't dissasemble my mizzen winches. It has an allen bolt inside the star shaped opening (where you would insert the winch handle). I turn and turn this bolt with an allen wrench but it does not seem to come out or even loosen up. I tried two different winches, same result. Any ideas?
Old 07-11-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
Not familiar with that particular winch, but my small Barients come apart that way. My larger ST Barients have a threaded piece on the top that has two holes in it for inserting a special wrench. The Barients on my old boat had a circular spring ring that had to sprung out and then the drum would come off. Make sure yours don't come apart in one of these other ways.
Old 07-11-2011
Kallisti's Avatar
Kallisti is on a distinguished road
When i removed my Barlow 18's it was by removing the allen screw in the center winch handle hole. The screw sits in a bushing at the bottom of the hole and removing it will allow the drum to be removed. It is unlikely that that screw would become stripped. The screw in mine was tightly threaded one was very stiff to turn. Hope this helps!
Old 07-11-2011
Cal28's Avatar
Cal28 is on a distinguished road
Barlow (and Barient) Winches Specifications, Parts Lists and
Service Information
Hope this might help ....
"It is only with the heart that one can see rightly; what is essential is invisible to the eye."
Antoine de Saint-Exupery
Old 07-11-2011
Cal28's Avatar
And these guys might be able to help you ... as they bought out Barlow ... Hutton-Arlo Winches
Barlow winch differences eharan Gear & Maintenance 2 01-16-2011 12:20 PM
Barlow 23 winch Mary51 Gear & Maintenance 9 04-03-2010 05:32 AM
Looking for Barlow 23 Single Speed Self Tailing Winch for Parts NS22Wren Gear & Maintenance 2 12-27-2009 07:58 AM
Barlow Winch Bearing - Hutton/ARCO never responds! belanich Gear & Maintenance 6 05-16-2007 05:07 AM
Barlow winch handle. jensw Gear & Maintenance 1 02-22-2006 08:48 AM
