Old 07-12-2011
dancurilla is on a distinguished road
Prop
Just fouled my prop. Engine runs a bit ruffer in neutral but forward and reverse sound good. Engine seems to be in order . Stuffing box seems normal. Why ruff in neutral?
Old 07-12-2011
Zanshin's Avatar
Zanshin is on a distinguished road
Did the engine stall when you fouled the prop?
Old 07-12-2011
No
Old 07-12-2011
treilley's Avatar
treilley is on a distinguished road
Something either bent, broke or moved. You are likely hearing a difference in the engine vibration. Check your engine alignment and dive the prop to make sure the strut and cutlass are good.
Tim R.
Living aboard in Portland, Maine
1997 Caliber 40LRC
and
Old 07-12-2011
Zanshin's Avatar
Sometimes you can get an injector clog a bit when the engine is stalled, or perhaps from too much compression when the engine is almost stalled. As you surmised, the vibration when in neutral would be not be affected by any mis-alignment aft of the gearbox (unless you are moving when it happens, which I assumed was the case but you should confirm). Have you run the engine under load to cruising RPMs since this happened? What sort of a diesel engine is it?
Old 07-12-2011
treilley's Avatar
A strut bent out of alignment would force the gearbox/engine combo out of alignment using the shaft log as a fulcrum. This could easily change the idle note of the engine. Also, I have seen components jammed into the engine compartment so tight that a slight misalignment caused an interference rattle against the component.
Tim R.
1997 Caliber 40LRC
and
Old 07-12-2011
I have run the engine at high rpms and it sounds good. As the rpms go down it starts to rattle more. Also my stuffing box stuffing seems to breaking aprt in pieces quicker.
Old 07-12-2011
I take it i shouldnt keep motoring?
Old 07-12-2011
treilley's Avatar
Please explain. What parts of your stuffing box do you see breaking apart? Normally the packing material would not be visible.
That would be a wise choice until you know more.
Tim R.
1997 Caliber 40LRC
and
Old 07-12-2011
HPLou is on a distinguished road
Send a message via AIM to HPLou
"I have run the engine at high rpms and it sounds good. As the rpms go down it starts to rattle more. Also my stuffing box stuffing seems to breaking aprt in pieces quicker."
Sounds like something bent (prop, shaft) or is out of alignment and is heating up the stuffing box to cook the packing. I wouldn't be motoring until I found out what the problem is.
Good luck.
Feathering Prop vs. Fixed Blade Prop Benevento Pacific Seacraft 70 02-11-2011 07:52 AM
New Prop & Shaft - install prop questions preservedkillick Gear & Maintenance 2 05-22-2010 08:46 AM
1 inch prop on 25mm prop shaft? lawsonmitchell Gear & Maintenance 2 11-28-2009 02:19 PM
Prop/Prop-Shaft Key Size? Skipaway Gear & Maintenance 7 07-29-2008 09:04 PM
Zincs for Sail Prop feathering prop jrbarn Gear & Maintenance 4 09-20-2006 10:40 AM
