Old 07-12-2011
cdhickey is on a distinguished road
Replacing transducer- can I use this thru-hull?
My current knot meter (analog, probably 30+ years old) is not working and attempts to repair it have failed. I'd like to replace it with a new Raymarine unit, but I'm wondering if I can just add a new transducer to the existing thru-hull, or if I will have to replace the thru-hull as well. Are transducers a standard size and profile?
Pictures of the current gear are below; the old transducer has a diameter of approximately 1 5/8 inches, and the old thru-hull is about 2 1/8 outside diameter. The thru-hull has a small extrusion on the bow side, with a corresponding notch on the transducer.
(These pictures were taken before the boat went in the water this year)
Skipper Chris
24' Northern 1/4 ton bobbing around in the frigid north Atlantic
Last edited by cdhickey; 07-12-2011 at 11:44 AM. Reason: Pictures not working; pictures working but ridiculously huge
Old 07-12-2011
Alive3and3Well is on a distinguished road
The following link provides specs on thru hull opening.
http://www.blueheronmarine.com/files...00_Install.pdf
My Raymarine equipment has Airmar transducer and is referenced from Raymarine website.
Be sure everything is in order and to spec as hull leaks are not fun.
Good luck!
Old 07-12-2011
captainrizzo's Avatar
captainrizzo is on a distinguished road
Install your current spedo and take your blank to West Marine. They stock the raymarine replacement transducers and the thru-hull comes with it. They will let you test for proper fit it in the store. Better to see it with your own eyes in my opinion.
-Riz
Hunter 306 Domingoman
"It is not the ship so much as the skilled sailing that assures the prosperous voyage"
George William Curtis
My Blog:
Best in hull transducer Waltthesalt Electronics 3 03-25-2011 09:20 PM
transducer/thru hull question inshallamiami Morgan 2 02-10-2010 07:56 PM
Through-hull transducer? flyingwelshman Gear & Maintenance 5 04-22-2008 11:27 AM
Thru Hull Transducer pixurman Gear & Maintenance 2 05-21-2002 07:04 PM
Transducer in steel hull davejean Gear & Maintenance 0 11-07-2000 08:55 AM
