Going Up The Mast - SailNet Community
post #1 of 12 Old 02-14-2001 Thread Starter
Going Up The Mast
When singlehanding what would be the best way to go up the mast. Wheather for a repair or to check out rigging for a problem. Last summer my roller furled got fouled up top and I did not have system worked for what situation
Bill S
express is offline
post #2 of 12 Old 02-14-2001
Going Up The Mast
I have seen a few systems that may work for you. 1. Install mast steps on the mast itself. Pros: always there for your use and not dependant on any halyards or the track for the main. Cons: You need to drill a bunch of holes in your mast and they disrupt air flow to the sails. 2. One of those mast ladders that feeds into the mainsail track. Pros: Up only when you need it, low cost, no permanant damage to the mast. Cons: If you can''t get the main down, you can''t use the product. 3. The top-climber. I spoke with a friend who uses a very similar device for rock climbing and he feels that this device is very safe for a single-handed solo to the top of the mast. Cons: You may bang against the mast as you climb.
hamiam is offline
post #3 of 12 Old 02-14-2001
RichH's Avatar
Going Up The Mast
Take a look at ATN''s new device for singlehanded mast climbing.
www.atninc.com
RichH is online now
post #4 of 12 Old 02-15-2001
Going Up The Mast
The top climber I mentioned is made by ATN!
hamiam is offline
post #5 of 12 Old 02-15-2001 Thread Starter
Going Up The Mast
Do you know anyone how has used one. It looks to be a good opion because you could use while the sail are up and easy to rig for use.
Bill S
express is offline
post #6 of 12 Old 02-15-2001
Going Up The Mast
I don''t know of any sailors that have used them, however, the exact same mechanism is used by my climber-friend and he claims that it is very safe and convenient to both ascend and descend with.
hamiam is offline
post #7 of 12 Old 02-15-2001
RichH's Avatar
Going Up The Mast
I took a hard long look at it at the Atlantic City Boat show... very impressive and well thought out.
I simply use mountain climbing ascenders.
RichH is online now
post #8 of 12 Old 02-15-2001
Going Up The Mast
i''ve got an atn topclimber used it couple of times at dock it works ok. yet to try under sail. climbing harness instead of sitting board could make a better product.
joe.
jhowe is offline
post #9 of 12 Old 02-15-2001
Going Up The Mast
How many of you guys have been up a mast underway???Different situations require different approaches. A guy can just walk right up the sailtrack on most boats, especially if she''s heeling. I''ve climbed the rigging on most boats just by grabbing hold of the high side rigging. For quick ones I''ll just grab something and spring up--anything''ll do really; but for serious time up shinney up with a line, to the spreaders. Hoist up yer bosun''s chair with your gear in it and tie it off where you need it, then climb in. Or climb up then hoist your halyard till your chair reaches you,..stand on the spreaders <<keeping your feet alongside the mast ONLY >>, climb into bosuns chair. But I''d like to say that, when it comes to general good seamanship and modern innovation....mast mounted styrups take my vote hands down!! All round ease of access to all levels of the stick--instantly. Ever held onto only one line while aloft?? Those mountain gizmos won''t hack it....For most work underway , as ugly as they are, a guy can get a REAL good hold and hook his legs around these things and, let''s face it, security aloft just makes it quicker to fix stuff so we can get back to sailing.....Rev......maritimetradition.com
munchimike is offline
post #10 of 12 Old 02-17-2001
Going Up The Mast
Hi, Bought a topclimber in Miami last year and used it many times. For me it has been the perfect answer to going up the mast un-assisted. I don''t know how a harness would be,but I find the seat to be very comfortable & secure. I''me 63 YO,and my only problem with it has been some sore ,unused muscles the next day
Marc
gershel is offline
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
