08-03-2003
Shaft Pump?
GROCO “SSC” - Engine Flush & Emergency Bilge Pump Kit
Intended for installation into the top of any existing seacock, “SSC” provides easy access to the cooling system for routine maintenance, or for emergency bilge pumping.
Once the seacock is closed, the quick release plug in the flush kit can be easily removed, enabling the connected engine to function as a high capacity bilge pump.
The (included) service adaptor provides an easy connection for dockside fresh water flushing, or adding antifreeze for winterization.
See:
www.groco.net/images/seacocks/SSC-Service-2004.jpg
Regards,
Gord
