07-18-2011
Originally Posted by MarkSF
I think it's an International topsides paint, dark blue. But it was done before I owned it, so I'm not sure.
Back when I restored my Rhodes 18 I used Interlux Brightsides and noted the white marks from fenders were actually scratches because that paint is not very durable.
Try the water test. If you wet the area and the marks appear to go away, they are likely scratches. If you can still see them, it is likely fender residue. Be very careful with solvents. Start very mild, like diluted simple green and work up from there.
Swore never to use it again. Perfection, a 2 part paint, does much better for durability. Painted my Ericson 35-3 spars with that. Still looks great after 5 years.
Tim R.
Living aboard in Portland, Maine
1997 Caliber 40LRC
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
