Old 07-18-2011
beej67's Avatar
beej67 is on a distinguished road
Oil leak, need info about replacement parts, opinions
Engine: Yanmar 3GM30F
Engine Number: E26758
The dipstick hole on this engine is set in a housing that's bolted onto the engine. It's leaking. Don't know for how long, or what could have started the leak. Between trips (about a month) all the oil ran out of the pan, or at least quite a bit did, because the dipstick read 'dry.' I put a liter in, sparked the engine up, and could see the oil leak out from around the seal on the housing shown above.
My current plan, pending Sailnet Approval, is to pull the thing off, clean it up, replace the gasket, and bolt it back on. Simply tightening it didn't seem to work.
The plan is complicated by the fact that I'm in Atlanta, the boat is in Panama City, and the housing shown in the photo is behind my muffler and my sink, so access is very limited. The above photo was taken by holding a cell phone with a flash into a dark corner into which I normally can hardly stick a wrench.
Question 1) Who can I contact to mail order the proper gasket? Should I replace the whole housing as well? I did not have time to pull it off last weekend due to aforementioned complications.
Question 2) I could watch oil leaking out of this housing as I ran the engine, but saw none when the engine was off. That seemed odd to me, considering the oil pan is not supposed to be pressurized. I'm of the mind to write off the difference in leak rate to engine vibration, but would welcome other opinions or potential additional problems that might indicate.
Question 3) (related) I did not check the oil on our way back in last time, but I didn't notice any engine overheating, oil pressure, or other idiot light issues. If the leak is exacerbated by vibration, wouldn't I have run myself out of oil on the previous trip? How could the leak have been 'sprung' in my absence?
beej67, Checkered Past, 1980 32' Pearson 323, Panama City FL
Old 07-18-2011
captainrizzo's Avatar
captainrizzo is on a distinguished road
Call Torresen marine in Muskegon, Michigan. They are an authorized Yanmar dealer and have always been extremely helpful over the phone.
-Riz
Hunter 306 Domingoman
"It is not the ship so much as the skilled sailing that assures the prosperous voyage"
George William Curtis
My Blog:
Old 07-18-2011
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
I suspect that you have a crankcase breather hose that is plugged. THAT would cause this, and the pressurization of your oil pan. Verify this FIRST.
IF you need to replace a gasket, for this application, I would use Gasketing Silicone without hesitation. The service temps should normally be < 300ºF.
Remove part
THOUROUGHLY clean both surfaces with paper towels
Clean again with alcohol and more towels
Apply Silicone
Put together
Let dry
Refill Oil
Enjoy...
Old 07-18-2011
beej67's Avatar
Talk to me about the crankcase breather hose. Don't have my manual in front of me. Is there a PCV valve I need to check? Could it just be crud in the hose somewhere?
Old 07-18-2011
sawingknots's Avatar
sawingknots is on a distinguished road
eherl,is on the right track,i don't think theres a pcv valve but i could be wrong,try disconecting the crackcase vent hose where it conects to the intake,observe the amount of blowby,if little or none your ploblem is a clog somewhere,if lots your engine needs rebuilding
Old 07-18-2011
eherlihy's Avatar
motoren.ath.cx: Yanmar motoren, motors engine | manual download
ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
Old 07-18-2011
eherlihy's Avatar
Because this job pays so well...
look at the Service Manual from my earlier post (it's locked so that I can't cut & paste) Page 170 of 231.
Navman Replacement Parts doons60 Gear & Maintenance 4 08-29-2010 07:14 PM
Westerbeke replacement parts jonlgauthier Gear & Maintenance 2 10-31-2007 09:20 PM
S2 10.3 - replacement parts for entryway S2Houston S2 3 09-18-2007 06:18 PM
Help with Ericson23 replacement parts... rbaroni Gear & Maintenance 2 04-14-2007 11:10 PM
Spar replacement parts BenDaniels Gear & Maintenance 1 04-02-2001 09:07 AM
