Old 07-18-2011
patrscoe's Avatar
patrscoe is on a distinguished road
Datamarine S-200DL Deph Sounder replacement
I'm replacing my Datamarine S-200DL depth sounder with a ST-60 Raymarine.
I will need to leave the existing transducer in until I haul out for maintenance in the Fall and fortunately I found a thread within Sailnet that had some really good info on resusing older transducers.
I hate to tear out my old instrument until I have all the proper wiring and connections; does anyone know what type of transducer cable does the Datamarine S-200DL used?
Thanks
Patrick
Old 09-07-2011
bahamamon is on a distinguished road
datamarine S200DL
Are the dimensions of your replacement unit similar to the Datamarine unit which you are replacing? I have the same inoperative unit. Only the audible alarm works, no digital display.
Old 09-08-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
Give these guys a call.
DMI Marine, Inc.
Old 09-09-2011
patrscoe's Avatar
I never did keep the Datamarine transducer; replaced them both. A S-200DL Datamarine depth finder had a 4" diameter opening but the ST-60 is a square but larger unit, and difference install. With care, install can be done without any patching.
Much better depth finder also the 5' shallow alarm does not go off while I'm in 40' of water. That usually gives you a immediate scare then your quickly realize you're in deep water and it's your faulty instrument.
Patrick
S2 11.0A
Chesapeake Bay, Va
Old 09-13-2011
ggray is on a distinguished road
I just looked at an old S-2oo DL and 4" sounds right. The ST-60 is square, but the hole is round, smaller than 4".
trouble shooting DataMarine S-200DL Depth Sounder alman Electronics 2 11-15-2010 12:51 AM
Need Datamarine Depth Replacement imathews Electronics 7 09-04-2010 03:53 AM
Datamarine Depth Sounder dryclean Electronics 5 11-03-2009 08:33 PM
Datamarine depth sounder jongoose Gear & Maintenance 12 06-03-2008 04:58 AM
Datamarine wind direction arrow - replacement? 7tiger7 Gear & Maintenance 2 07-07-2007 09:19 AM
