Or OMMM for short.
Story: I bought an Oday 25 1976 this April. Last year, the previous owner sold the original motor and bought a late 90s/Early 00 Mercury, 5hp, 2 stroke. I think the previous motor was larger. She mentioned that it was mounted a little too high and popped out of the water some. It came with this type of mounting:
Garelick EEz-In
The motor WAS poping out every time we hit a wave, so I thought I was smart and replaced that black plastic part on the mounting with a piece of pressure treated wood, screwing it in near the top of the wood rather than the bottom. This turns out to not be a stable situation, the screws are in the way of the gripper thingie.
Now I'm noticing that the spring things on the mounting (metal, toward the bottom) are broken and one fell off, and it's actually only screwed into the boat in two places - the bottom left and top right. If one of those pop my motor is will fall in the water. I tied it up with rope in the meantime, but...
It seems like I should just replace the mounting. It's messed up, and when the plastic part was on, it never could get in the water deep enough, no matter how low I set it. I'm not sure if I could get new springs to repair it anyways. I assume I could remove the mounting, get new springs, screw it into the boat lower, fill up the old holes, but this seems crazy.
QUESTION!
The marine store told me that I CANNOT get a mounting like this:
Garelick EEz-In because it's rating is 7.5hp up. They said that my mercury would not be heavy enough to hold it into the water. Is this true? Can I duct tape some bricks to it or something? :-P I need the longer REACH that these larger brackets seem to have, but they all seem to be rated for larger motors. I'd like to keep the option open for getting a larger motor someday, too.
I'm tempted to get something like this:
Garelick EEz-In and mount it exactly where I need it. I don't think I'd miss the up& out function too much, I'm strong enough to lift the motor if I'd need to.
Suggestions, advice, critisicm welcome. I'm not sure if this is really a good motor for my fat-a$$ oday anyways.
