07-22-2011
Originally Posted by Silvio
You have an outboard, turn the motor and drive the boat in whatever direction you need to go in reverse. Prop walk should only be an issue with an inboard. It may take some practice or repositioning where you sit but you should be able to kick the outboard over and keep the rudder controlled in the process.
Practice where you aren't in a tight spot and are less likely to hit another boat.
Good luck.
Much more controllable than an inboard, but outboards can fight prop walk too. I've had outboards turned full deflection against their natural prop walk and essentially back up straight. Sounds effective, unless you were actually hoping to turn in the direction of the deflection and assumed the motor would pull you there.
In the end, prop walk has to be understood and managed.
Practice is the way to go. My fav is a fairly empty mooring field and use a bouy as your reference.
Jeanneau 54DS
