How easily driven is a particular hull? - Page 2 - SailNet Community
post #11 of 14 Old 07-21-2011
tommays's Avatar
The Cal 29 has a 24' LWL and is really stable
The J24 has a 20' LWL not so much in the stable
The A4 motor is mounted at or near the max 15 degree angle BUT the outboard was level and the Cal still had stern squat were as the J24 had littel if any stern squat at the same speed
It just seems to be the nature of pushing that style hull VS the C/E from the sails being more or less in the center of the boat and if it squats under sail it does it level
The question is how much HP does a 400 to 500 SQFT sailplan make in twenty knots of wind as it takes some honking wind to break 7 knots on the Cal
The Cal will go above 6 knots under power BUT the water gets really deep in the cockpit and its NO fun standing in 12" of water and using 3 times as much fuel to go 1 knot faster
The Cal was built with and still has its ordinal 12 x 8 prop which is a bit big BUT does not seem to have hurt the motor as it still is within spec at 41 years
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #12 of 14 Old 07-21-2011
"Sparkie"
j34035's Avatar
Theoretical hull speed = (Sqrt of LWL)*1.34. You can reach that speed with a reasonable amount of energy (sail or mechanical) but to exceed that you have to have a lot more power. The exception is a planing boat or when you get lucky and can use following seas and surf down the faces (thats fun). Again that is theorectical hull speed and can be affected by any of the variables mentioned above, but every non planing boat has a definate point that it reaches this transition.
DD
Doug
Jboat J/37c (new to me Jan 2011); J/22 #1003
j34035 is offline
post #13 of 14 Old 07-21-2011
Originally Posted by davidpm View Post
Would you mind mentioning a boat or three that pop into your mind in the 28 - 33' or so size.
Long waterline for lengh:
Fair lines:
Rule induced bumps:
Narrower vs. fatter.
I know you have been doing this a long time and I would like to look up some specific boats and see the difference.
It seemed to me that the Catalina 27 is a little better hull shape than the Catalina 30 according to this criteria, yes?
Just for fun, compare a Farr/Mumm 30 One Design to a Catalina 30.
puddinlegs is offline
post #14 of 14 Old 07-21-2011 Thread Starter
davidpm's Avatar
That's not fun it's just cruel.
davidpm is offline
Engine Driven Bilge Pump TwoD83 Gear & Maintenance 13 06-27-2012 06:22 PM
Alternator driven tachometer, how does it work? downeast450 Diesel 2 08-26-2009 12:33 PM
Have you driven backwards? deniseO30 herSailNet 17 10-06-2007 05:20 AM
Engine-driven refrigerator/freezer poopdeckpappy General Discussion (sailing related) 6 05-30-2007 01:22 AM
ENGINE driven Watermaker tjkassen Gear & Maintenance 2 02-07-2005 02:03 PM
