Like Tree1Likes
Old 07-23-2011
tkawika is on a distinguished road
Wire Lifelines vs Rigid Stainless steel??
My question stems from the fact that I was originally advised to get 1" Rigid Stainless Steel (SS) rail in place of your standard lifeline SS wire. I actually hired someone to install 1" SS around the whole boat, but after a few visits from more experienced sailors and then from some reputable welders I was advised against it for a few reasons. The main reason was cost. To do it right I needed to add twice amount of 1" SS I had originally ordered and another 6 Stanchions. My spans were longer than the standard 40" (mine were over 80'') and needed more support. I have redesigned the whole deal and I using only 20ft of the 60ft of 1" SS to beef up and the stern section and I am going back to wire for the rest of the boat.
Besides the cost, is there any other reason why to stay away from rigid rail??
Thanks,
TK
Tkawika
1972 Coronado 35 MS "Ku Ikaika"
(Hawaiian for "Stand Strong")
"Negative, I am a meat popsicle." Korben Dallas
Old 07-23-2011
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Thanks,
TK
Because it's ugly.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
Old 07-23-2011
fryewe is on a distinguished road
"Because it's ugly." ...+1.
Why use wire? Why not rope? Strong, easily replaced, easily inspected, looks good...
Old 07-23-2011
I have looked at Dyneema, but its just as expensive as cable and more in some cases. I have seen this Vectran on ebay, is this the same as Dyneema? Correct me if I am wrong the gates would still need to be wire?
Tkawika
Old 07-23-2011
mitiempo's Avatar
A tensioned wire or synthetic rope lifeline has some give and can take a lot of abuse, as is common on a sailboat. A solid rail will dent if hit hard when docking or whatever. Suits powerboats better as they are less likely to abuse it like we do.
tkawika likes this.
Brian
Old 07-23-2011
deniseO30's Avatar
Lies about her age
Thanks,
TK
Allot of information seems to be missing. uh... WHAT are/were you thinking and why?
Do you have a project boat?
Was your boat missing stanchions when you got it?
What make year boat? A
Are you or your crew that fearful of falling over board?
Who was this "adviser"?
What would your boat be worth after this "improvement"?
Old 07-23-2011
I was thinking that it was stronger than lifelines and allowed for some more mature crew to hold on to.
Aren't all boats projects? haha
No missing stanchions, just a boat from 1972
Sorry, its in my signature. 72 Coronado 35ft CC
Yes, some of the crew don't have the best balance, but this has changed and these crew members will be tethered whenever on our way.
, exactly, but a family acquaintance.
Not an important factor, but probly the same as before.
Thanks for the response,
TK
Tkawika
Old 07-23-2011
capecodda is on a distinguished road
Tkawkia,
We extended the stern rails all along the cockpit where we convert to wire. We did this after looking at a few other boats with the same design, and we like it. Not only is it barely noticeable, but it has great utility. Great to lean against while sitting to leeward and beating, nice to hold onto, more places to hang your stuff (barbecue, horseshoe, dingy outboard, etc.), and was able to get the bimini bow's off the deck attached directly to the tubing, which created more room to sit on the coamings.
Good luck with yours
Old 07-23-2011
Originally Posted by capecodda View Post
Tkawkia,
We are only half way around the cockpit, but since I have a center cockpit its probably as far as yours. Do you have any pictures you can share? Would love to see other ideas.
Thank you,
TK
Tkawika
Old 07-23-2011
Stainless Steel Bottom cabron99 Gear & Maintenance 8 05-19-2010 04:37 PM
Lifelines: Bare Wire vs. Vinyl Coated Debate Sabreman Gear & Maintenance 19 12-25-2008 11:50 AM
Stainless Steel... merttan Gear & Maintenance 14 04-12-2008 07:59 PM
Combination stainless steel chain/ galvanized steel anchor Grigrigrigoris Gear & Maintenance 11 07-03-2005 03:46 PM
Stainless Steel Chainplates Wire Wheeled emma41 Gear & Maintenance 3 05-22-2003 06:14 AM
