Old 07-23-2011
MarkSF is on a distinguished road
Cam cleat for jib furler line?
It was a bit windy on SF bay yesterday (ie, a normal day!). Saw 29 knots on the wind speed indicator going upwind and 25 knots on a broad reach.
Not surprisingly, we reduced sail but it was a struggle with the jib furler line. It's hard to cleat it off when there's any tension on it without cleating your fingers too!
So I was thinking of adding a cam cleat before the cleat proper. That would hold the line while you cleat it properly. Has anyone else got one and/or tried it?
My last boat, a daysailor, had one and it worked nicely, it seemed.
Old 07-23-2011
deniseO30's Avatar
Lies about her age
This works out very well for when I'm single handing, Normally the jib sheet is in the cam cleat (in the photo that's the traveler line) I use supple yacht braid for jib sheets and I'm able to toss it around the winches during most conditions. ON my boat the primaries are too far forward of the wheel. On the port side where my furler line is the cam cleat comes in real handy too.
Old 07-24-2011
I like that idea, one on each side. Only thing is that the cam cleats are typically 500 lbs load - think my jib sheets might exceed that sometimes.
Old 07-25-2011
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
On your boat a mid-sized Ratchet Block would do nicely. See Harken Ratchet Blocks
Old 07-25-2011
tommays's Avatar
I am new to the furling headsail thing BUT i find if i just reach off for a short bit to unload the sail it rolls in pretty easy
I keep it on a regular cleat as i find i need a few wraps on the cleat to let it out under control when its blowing
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 07-25-2011
GeorgeB is on a distinguished road
I have a single Harken block with a cam cleat and stanchion mount for my furler line. It is set up to turn the furling line about 170 degrees, giving me a fair lead into a primary winch in case if I have to put some real “meat” on the furler (which occasionally happens on SF Bay). My boat is a 34’ and the cam cleat handles the additional load quite well.
Old 07-25-2011
Hi George,
Yesterday I worked on it a little, and added a Harken 7402 ratchet block to the stantion near the back of the cockput. The line now does a 180 around this line, then forward 2ft back to the cleat.
The arrangement worked great in the slip.
My only nagging doubt is how much load I'm going to put on that block. It's rated for 500lbs operating, will fail at 2000lbs. However when you do a 180 turn, those ratings are halved (or, rather, the load is doubled)
Do you think I'll exceed 250lbs on the jib furler line? It's a 31 ft boat, jib is 250 sq.ft.
Is your block a Harken 57mm carbo one like mine? Sounds like it's been OK.
Old 07-25-2011
Mark, here is my set up. I have since “turned” the cleat so it makes more of a 170 degree turn so it will have a fair lead into the winch. I run larger genoas than you and have not had a problem yet. Although, I rarely “roller furl” unless I get caught in the slot in nuclear conditions (but I guess that is your SOP too).
Old 07-25-2011
ccher is on a distinguished road
I had the same issue as MarkSF and added new block and cam cleat for the furling line on my C310. Now furling is a non event in any wind conditon.
Flyaway
Cranes Creek, VA
Old 07-25-2011
George, thanks for the pic. I am curious as to what the purpose is of the tape measure duct taped to the deck!
Jam cleat on the jib Sublime General Discussion (sailing related) 5 05-28-2011 08:18 PM
Continuous Furler line overbored Gear & Maintenance 3 05-17-2011 05:44 PM
Running roller furler line outside stancheons.. groundhog Gear & Maintenance 19 04-27-2009 01:23 PM
Changing a V-Cleat to a C-Cleat? funjohnson Sailboat Design and Construction 11 08-21-2008 10:14 AM
Cleat?? sailboter97 Gear & Maintenance 4 04-08-2002 05:25 AM
