07-26-2011
With a little more info I will take a look at work for some solutions for you. Are your port/strd tanks plastic ? Are the access ports from the top or the side? Is there anywhere you can see the sides of the tank or the top ?
Outside the tank sensors us well nuts, so you will have to drill holes in each tank marking 1/3, 1/2, 3/4 and full.
When using a rod, you have to just drill one hole on top so installation Could be a little easier. Rods you just cut to length determined by the depth of your water tanks.
Things to ask yourself. Is there room to get a drill (right angle drill) in position to make the holes that are required. What wires need to be run and where too. There is a little more wiring with outside sensors because they use a diode that has level wires to be attached to the well nuts. Its still an easy wire job. What kind of gauge do you want and where.
"Plan the work then work the plan"
I will see what I can find
