Old 07-24-2011
sailing320's Avatar
sailing320 is on a distinguished road
Holding Tank Paint
Can anyone recommend a paint that I can apply to the inside of an aluminum holding tank to extend the life? The tank is in good shape now but I do not want problems later.
Old 07-24-2011
pdqaltair's Avatar
pdqaltair is on a distinguished road
The odds of achieving a good bond on a used tank without good access for surface prep are long. I you have spotty failures, the corrosion will focus on those spot, causing failure even sooner.
Unless you can install a suported lining (epoxy with a few layers of FRP included) it will likely do little good. Much depends on the access.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Old 07-24-2011
jimjazzdad's Avatar
Bluenoser
jimjazzdad is on a distinguished road
Yes, the issue will be getting something to stick to the aluminum. I am about to try the same thing with my aluminum holding tank - I plan on using about five coats of coal tar epoxy. Hopefully that will build into a sort of liner. Another thing you could try (if the holding tank can be removed) is to take it to one of those places that does sprayed-in pick up truck box liners - Armorguard, Rhynocoat, etc - and have them coat it with sprayed on polyurethane. Why did manufacturers every use aluminum for holding tanks???
Old 07-24-2011
mitiempo's Avatar
For all the effort I would replace it with a plastic tank, either off the shelf (Ronco Plastics - Marine Water Tanks, RV Water Tank, Auto Detail Tanks, Water Tanks) or custom made. They are not that expensive and they will fix the problem for a decade or so. I doubt you will get a good bond and you will probably re-visit the issue in a year or 2. To do it properly you will have to have full access to the tank interior anyway.
Brian
Old 07-26-2011
sailing320's Avatar
Thank you for your advice.
28I holding tank 28islander Islander 5 03-16-2011 01:12 AM
O/I 41 holding tank tatoloco Morgan 4 02-01-2011 11:50 AM
Convert existing steel freshwater tank to blackwater holding tank? patrickstickler General Discussion (sailing related) 7 09-24-2010 07:55 PM
Dye in holding tank davidpm Gear & Maintenance 5 09-27-2009 12:05 PM
Holding Tank Scubado Gear & Maintenance 14 04-01-2004 11:24 AM
