Calling all electic drive boats - Page 4 - SailNet Community
 3Likes
post #31 of 63 Old 08-01-2011
Once known as Hartley18
Classic30's Avatar
Dock
Cameron,
Virtually all of the big boy's toys these days have their engines running all the time in order to power such things as canting keels plus of course the plethora of electrical gear.
??? I never noticed..
Must take a closer look next time the TP52's are out on the water.
Classic30 is offline
post #32 of 63 Old 08-03-2011 Thread Starter
davidpm's Avatar
Originally Posted by mgunning View Post
Also most electric propulsion users select the largest prop possible to take advantage of the benefit of the electric motors torque.
Racers will do almost anything to win including painting a wood anchor galvanize to reduce weight but still pass the anchor requirement.
I wonder if anyone has rigged a quick release on the prop so someone could dive on it and pop it off.
The fact that I thought of it and it is possible means someone has done it.
davidpm is offline
post #33 of 63 Old 08-03-2011 Thread Starter
davidpm's Avatar
I just googled it and found this:
How did Rescue Minor's quick release prop work??
Told you!!!
davidpm is offline
post #34 of 63 Old 08-07-2011
Swabbie
Boat: 1971 Coronado 35
Motor: Mars Brushless 8KW
Controller: SevCon Millipak
Batteries: (8)Trojan T-105
Charger: 48v Golf Cart charger
Unfortunately I haven't had the opportunity just yet to get the boat in the water. I'm hoping to get it in next month ( crossing fingers )
The reason I went with electric: The boat had no current motor in it and I had started searching for alternatives. I am an Electronics Technician in the Navy and have absolutely no knowledge of Diesel engines so I decided on the electric motor. The Motor/controller/batteries and charger all came from one guy who had purchased the kit and decided to go a different route. I took it all off his hands for $2k.
I will post more of the performance when I get a chance to actually use it. Right now i'm using the two bladed prob that was already there but looking to get a larger 3 bladed.
Chris
optikul81 is offline
post #35 of 63 Old 08-08-2011
Hi Chris,
Are you going to make the mounting frame and reduction or is it all together in a unit already?
Good luck with your install.
Mark
Mark F is offline
post #36 of 63 Old 08-08-2011
Swabbie
The kit came with a 2:1 reduction setup. Looks like the same one ElectricYacht uses.
Link to Photo
post #37 of 63 Old 08-08-2011
Hi Chris,
That's quite a score for $2000. Do you know who made the setup? I like the heat sink for the controller. How is the unit switched (throttle &forward/reverse)?
Mark F is offline
post #38 of 63 Old 08-08-2011
The issue here is even more complex for the race committees. Here is something we have experienced. The electric motor propulsion system has a greater drag than a free wheeling diesel with a like prop. Also most electric propulsion users select the largest prop possible to take advantage of the benefit of the electric motors torque. How do you address the issue that when racing with an electric system there is no free wheeling of the shaft and there is a regeneration possibility. This happens for most at around 5 knots and is a benefit to the cruiser but it does slow down the racer. It is possible to install a disconnect but seems to be an item that is of little use to most sailors. It is possible to use a feathering prop but you likely will lose regeneration capabilities.
Mike
With a lot of the feathering props you can "trick" them open to achieve regeneration. To do this when you are sailing, but the motor in reverse to open the prop, then neutral. The drag on the prop will keep the prop open and start regenerating. To feather the prop, simiply shift forward and then neutral and the prop will return to the feathered position.
-geoff
home | straightturn.net
swashbuckler_geoff is offline
post #39 of 63 Old 08-08-2011
Greetings Chris,
It is an Electric Yacht frame and it looks like someone bought a Mars brushless motor and Sevecon Millipac controller and adapted to the frame. If you have questions installation, let me know. I can probably help you.
My electric boat:
1976 Cal 3-30
Displacement:10,500
loa: 30'
lwl: 26.5
Motor: Electric Yacht 100ibl
batteries: 130ah 48v lithium
power draw:
20amp 3.5 knt
80 amp 5 knt
-geoff
post #40 of 63 Old 08-08-2011 Thread Starter
davidpm's Avatar
Chris
Sounds like a nice setup. I have heard that the right prop buys about a knot of speed so would like to see if that holds true in your case.
davidpm is offline
Calling all techies! :o) Donner74 Electronics 12 07-29-2011 10:04 PM
calling all TOCKs donroy Tartan 2 10-08-2009 04:45 PM
Upgraded to electic start Nissan 8 HP but... lumpen5 Electrical Systems 4 04-02-2009 09:54 AM
Need recomendations for electic windlass lavida Gear & Maintenance 13 05-03-2007 11:35 AM
calling all NC sailors kokopelli9 General Discussion (sailing related) 7 11-01-2002 02:09 PM
