Old 07-24-2011
Sundownsailing's Avatar
Sundown Sailing
Sundownsailing is on a distinguished road
Two part Varnish or traditional?
I have applied gallons of varnish using traditional methods and now I am faced with a recommendation for a two-part varnish system. Any suggestions would be appreciated.
Old 07-25-2011
billyruffn's Avatar
billyruffn will become famous soon enough
I've used two part "varnishes" on cabin soles with good luck. It stands up well to foot traffic, abrasion, etc. I use traditional varnish in all other areas of the boat.
Where are you considering using the 2 part product?
Old 07-25-2011
mitiempo's Avatar
Two part varnishes are tougher as posted. Good for higher wear areas. They cannot be used over traditional varnish. Traditional over two part does work.
Brian
Old 07-25-2011
treilley's Avatar
treilley is on a distinguished road
A lot of the two-part finishes dry quickly and also allow for wet on wet re-coating which makes the job much faster. They also cure to a very durable finish.
In the past I have used Bristol Finish, Honey Teak and another I cannot remember the name. I like the Bristol the best.
Tim R.
Living aboard in Portland, Maine
1997 Caliber 40LRC
and
Old 08-03-2011
kev1951 is on a distinguished road
How do you keep bubbles from forming on the rails when using the honey teak Sshould i keep the componets of the honey teak in the fridge???
Old 08-03-2011
turbulicity's Avatar
turbulicity is on a distinguished road
My impression is that the two part varnishes don't stand up to the UV any better than the quality traditional varnishes. When the time comes to redo, much harder to get the two parter off. So, I will stick with epifanes for outside brightwork. Two part would be good for cabin sole, table top and such.
1978 Gulfstar 50'
Clark Sailing Dinghy 10'
Old 08-03-2011
sanjuanman is on a distinguished road
We are about to undertake a major overhaul of our bright work... if we were to use a 2 parter on the heavy-use areas and traditional on the rest... any opinions\experience on the difference in color... or is it pretty darn close?
Old 08-04-2011
Catboat
Spyder is on a distinguished road
No, it's not close at all. Traditional varnish produces a cats-eye beauty that seems to glow. The two part finishes are relatively flat, but are tougher. I use 2 part on areas I can't see while sailing, but varnish in the cockpit.
Cheers,
Dick
Old 08-04-2011
rbrasi's Avatar
rbrasi is on a distinguished road
What would you use on a tiller? Two different types of wood....
1968 Cal 2-30
Sandpiper 2
MDR
Old 08-04-2011
mitiempo's Avatar
I would use traditional varnish on a tiller - I prefer Epifanes. When not sailing the tiller should be covered. That way it will last years.
Brian
Tags
two part , varnish
Applying Perfection 2 part varnish to new cabinb sole - sand or not? Northeaster Gear & Maintenance 12 08-09-2011 08:31 AM
Valiant 40 progress part three, varnish and rigging. CharlieCobra Gear & Maintenance 3 04-12-2010 08:35 PM
uni-fid vs traditional fids coondogger Gear & Maintenance 4 04-25-2007 01:25 PM
Interlux Perfection Varnish (2 part) mikehoyt Gear & Maintenance 0 05-31-2004 05:50 AM
traditional sailing rig headwind Gear & Maintenance 1 06-26-2003 05:55 PM
