07-25-2011
Zinc Collar on Pedestal Shaft, Okay?
Hi all,
I have an Edson steering system on my boat. A while back I noticed that my wheel was rubbing lightly on one of my gauge pods, which was not normal for my setup. What I found was that my wheel is held in place by a stainless snap-ring in the rear, and the keyed shaft and nut in the front (aft end).
While I did replace the snap-ring, and some spares, it sure doesn't give me a lot of confidence in the strength of the stop behind the wheel hub. I was considering adding a stainless collar behind the wheel to act as the stop. I have plenty of room, so it should work. While looking for those, I came across zinc collars that should be able to serve the same purpose (for much less $). There will not be a lot of force against the collar, but a simple snap-ring leaves me a bit nervous.
At the same time, I am looking at making the wheel easily removable so that I can open up the cockpit while anchored. The new collar would greatly enhance my ability to tighten the wheel nut without bending the snap-ring.
Comments and/or suggetions are most welcome.
Thank you in advance.
Cheers, Bill
Odyssey, '79 CSY 44 Cutter
Channel Islands, CA
"There is no unhappiness like the misery of sighting land (and work) again after a cheerful, careless voyage."
Mark Twain
