Old 07-26-2011
sandycohen's Avatar
sandycohen is on a distinguished road
Bilge pump discharge setup
Hi All -
The boat I purchased about 5 months ago has the bilge discharge positioned about 3 or 4" above the flat water line - obviously, it's well below the heeled water line.
I see no signs that this was not the original setup, or that there was ever accommodation for a vented loop or other siphon break. When I bought the boat it did not have a check valve. I don't think the bilge has a check valve, because when I turn it off, the water column that hasn't been discharged flows back into the bilge pump.
The boat has been sailed often and hard - what am I missing in this setup that has kept it from sinking when heeled?
Old 07-26-2011
PorFin's Avatar
Señor Member
PorFin is on a distinguished road
Originally Posted by sandycohen View Post
...what am I missing in this setup that has kept it from sinking when heeled?
The anti-siphon loop and valve above the max heeled waterline.
(although after rereading your question, I think you may be asking why hasn't she sunk before you noticed this... that's a good question. Luck maybe? Maybe a check valve integrated into the bilge pump?)
Old 07-26-2011
sandycohen's Avatar
Sorry - I was unclear. I meant what has kept the boat from sinking for 30+ years with this setup, that seems to be basically inviting water in at any angle of heel.
Old 07-26-2011
mitiempo's Avatar
Luck - change it by adding a high loop with a anti-siphon at the top.
Where is the outlet located?
Brian
Old 07-26-2011
sandycohen's Avatar
Amidships, about 3" above the waterline at rest, starboard side,
Old 07-26-2011
capecodda is on a distinguished road
If the hose run in the discharge is above the water line when healed, even if the discharge is submerged when healing, and the bilge pump doesn't happen switch on to charge the line while healed, your boat might not start reverse siphoning. So yea, lucky I think. Adding anti-siphon loop would be good insurance against your luck not continuing .
Don't ask me how I learned about this. Seeing all that water below is something you remember for a long time.
Old 07-26-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
What the traditional bilge discharge route? High loop, then d/c just under the rub-rail? Out the stern? Into the cockpit?
Old 07-26-2011
Barquito
Boat's I've owned discharged in the stern. Usually a high loop with anti-siphon valve located aft, then out, sometimes even under the counter (as long as the loop is high, this is OK I think).
H22 bilge pump discharge Carina22 Hunter 0 07-16-2011 06:30 PM
bilge pump discharge thru hull raayres18 Gear & Maintenance 13 01-02-2011 10:53 PM
Bilge Pump Discharge Location, Other Qs montenido Gear & Maintenance 2 02-04-2009 06:26 PM
Bilge Pump Discharge - New Thru Hull ??? Terry Clarke General Discussion (sailing related) 4 05-10-2003 05:07 PM
Bilge Pump Discharge - New Thru Hull ??? Terry Clarke Gear & Maintenance 3 05-01-2003 06:25 AM
