Old 07-26-2011
dvuyxx's Avatar
Super Member
dvuyxx is on a distinguished road
Gate for Slugs Thingy
The gate that closes the entry for my mainsail mast slugs (term???) seems like it's worn and not closing all the way snug to the mast. This makes my slugs get stuck one-by-one as I haul them up. I have to push them by hand past this point where it's catching. If I wad something behind the cotter pin to tighten the door, it helps and the slugs don't catch.
Has anyone ever replaced this hardware? I can't seem to find one in the usual places. I thought about putting a washer around the cotter pin to give it a squeeze ... but that doesn't seem like a permanant solution.
I'm sure this part has a salty name like the "wellingham" or the "blarrgengate."
See photo:
https://picasaweb.google.com/lh/phot...eat=directlink
David
Severna Park, MD
Pearson 35 - s/v Tiger Lily
Old 07-26-2011
JSL3's Avatar
<----- thinking of this
JSL3 is on a distinguished road
How about this:
MetalMast Mainsail Gates
~Jim
Ramble On
1986 Pearson 28-2
Old 07-26-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
I have the same design on my watchamacallit. It might help to have a long pin in the hinge end too. I also filed the corners in the slot smoother. As a last resort, I was thinking of bending the gate a little. Replacements are available.
I would be interested to know others solution.
Old 07-26-2011
dvuyxx's Avatar
Super Member
Jim and Barquito, thanks so much! I will definitely look at MetalMast ... it seems to the be the right part. "Mainsail Gate" ... what kind of name is that?
David
Severna Park, MD
Old 07-26-2011
dvuyxx's Avatar
Super Member
Woo boy ... $89 clams! They seem to be the only purveyors of this part.
So, Barquito, do you think that our hinges are not aligning because they are worn/warped? I want to make sure a new part would solve the problem.
David
Severna Park, MD
Old 07-27-2011
Barquito's Avatar
Barquito
Not sure if I Could see clearly enough on the pix, but it looked like there wasn't a pin. Even if there is, mine has a lot of play in the hinge. I Figure mine would work fine of there was no play in the hinge and it would stay completely closed.
Old 07-27-2011
johnnyandjebus's Avatar
johnnyandjebus is on a distinguished road
dvuyxx
I have to confess I have no idea how the hardware you are talking about works???
With that said if it is used to prevent the mainsail slugs from sliding out of the track, perhaps a slide stop would be a good alternative??
See product K-11198 on the following page
Please disregard this post if I am completely off base on this.
John
Old 07-28-2011
Barquito's Avatar
Barquito
Usually the mast gate is a few feet above where you would want the sail to stack. It is just a matter of getting the thing to position in exactly the right place.
Spring Support Thingy rireefguy Gear & Maintenance 1 05-07-2009 09:40 AM
transom stanchion tic tac toe thingy souljour2000 Gear & Maintenance 3 09-02-2008 12:02 PM
Docking Grappling Hook Thingy... djodenda Gear & Maintenance 70 05-19-2008 11:13 AM
knot meter paddle thingy hertfordnc Gear & Maintenance 6 05-03-2008 03:44 PM
Boom Holder Thingy ? jbarros Gear & Maintenance 3 12-13-2003 05:42 AM
