Old 07-27-2011
ElTiburon11 is on a distinguished road
Cabin Sole (Teak and Holly) refurbish
I am refurbishing the teak and holly sole of our Tayana 47 and have run into an interesting development. I have used the same techniques (sand to bare wood, apply coatings) and find that different boards have a different tone...some darker than others. I have made sure my technicque is the same for each one and am baffled. The original color is a nice blond teak with the results I am getting are darker. I've talked with the manufacturer and they've indicated that differences in wood can cause this. My question, is there any product that I can put on on the first coat that will not absorb into the grain and therefore maintain the light color. Advice is appreciated.
ElTib
Old 07-27-2011
deniseO30's Avatar
Lies about her age
True varnish is dark, new polyurethanes stay allot more clear when applied. You may have to bleach the teak to get it lighter otherwise. Oil = dark with age and teak is full of oil.
Old 07-28-2011
PorFin's Avatar
Señor Member
PorFin is on a distinguished road
ElTib,
Denise is right -- you may need to bleach the teak to get a uniform color from board to board. I've found two-part bleach to be a much easier product to use than oxalic acid crystals dissolved in water. If you only need a single acid wash, you won't need to rinse/neutralize the acid before the final scuff sanding and finish application.
Old 07-28-2011
treilley's Avatar
treilley is on a distinguished road
Are you sure you have not sanded through the teak and are seeing the underlying substrate? Teak veneer is usually very thin.
Tim R.
Living aboard in Portland, Maine
1997 Caliber 40LRC
and
Old 07-28-2011
PorFin's Avatar
Señor Member
Trielley,
One thing that many Taiwanese boats share is an abundance of teak -- both a blessing and a curse. Most cabin soles of these babies are about 3/8" teak/holly (or another light wood) glued over top of 5/8" plywood.
That's assuming that the assuming original sole hasn't been removed/replaced at some point along the way.
Old 07-28-2011
treilley's Avatar
Originally Posted by PorFin View Post
Trielley,
Good point. Somehow I thought the OP mentioned veneer.
Tim R.
1997 Caliber 40LRC
and
Old 07-28-2011
MARC2012's Avatar
MARC2012 is on a distinguished road
Gee I thought teak & holly were two different,mine is?mar
Old 07-28-2011
Sabreman's Avatar
Sabreman will become famous soon enough
Having built & finished teak furniture as well as having refinished the interior of Victoria, I have some experience here. Many planks of a specie vary wildly in color and grain. Graining will also affect final finish color, too.
Assuming that you did not sand through to the substrate and are dealing with only teak and holly, I'll say that unfinished teak is generally light in color. When a finish is applied, it then darkens the degree of which varies according to the type of finish applied. True varnish will darken the most because of the oils. Urethanes (virtually bullet proof) darken less, but add a nice warm glow, IMO.
Wipe a section of teak with plain water. This is the best that you can do without bleaching. IMO, bleaching is not an option (for me) because it casts a really weird silver or white tint to the wood. I'd rather paint it than abuse the poor piece of wood.
A foolproof way of limiting the toning of any wood is to isolate it from the finish. Apply 2 or more coats Zinsser's Shellac Sealer followed by water-based Urethane. NOTE that I do NOT recommend this course of action. It will work, but aesthetically (again, to me), the warm glow imparted by a oil-based finish is comforting. While a water-based urethane will not darken a wood after it dries, it is notoriously difficult to flow-out properly. Most woodworkers stay away from water-based finishes for this reason.
Examples of the variety of teak follow:
Plantation Teak Corner Cabinet: FURNITURE
Victoria Interior with light teak floor and darker paneling: VICTORIA (and her mistress)
Sabre 38 "Victoria"
Old 07-28-2011
Stu Jackson's Avatar
Stu Jackson is on a distinguished road
Saberman's right about this: it is notoriously difficult to flow-out properly. Most woodworkers stay away from water-based finishes for this reason.
Guess I'm not a woodworker and learned the hard way, had to redo a complete piece - of course it was the biggest!!!
They all look a bit different, too. The smaller pieces over the bilge came out darker than the rest of the sole. The veneer looked the same thickness but the bilge covers were thicker substrate.
It's wood, it will always look somewhat different.
Stu Jackson, C34, 1986, M25 engine, Rocna 10 (22#)
Teak & Holly Cabin Sole willysail Gear & Maintenance 22 01-11-2012 03:26 PM
Advice refinishing teak and holly sole mcagney Gear & Maintenance 11 09-24-2009 07:03 AM
teak and holly sole underwater mysticsailor Gear & Maintenance 11 02-16-2009 05:06 PM
Making the illusion of a Teak & Holly Sole?? landlockvasailor Gear & Maintenance 17 06-06-2008 11:46 AM
Replacement Teak and Holly Sole (C&C 37) thomsonjd Gear & Maintenance 2 11-29-2001 05:17 PM
