07-29-2011
Did you bed it inside the hull (not thru-hull as with a paddlewheel for knot meter)? If so, the material you bedded it in might have loosened a little from the sole, or the transducer puck may have come loose from the bedding material. If there are any voids, it might not see thru the hull. I've had this problem from time to time on my boat. It's a pain, but it's easy to solve.
Sailing isn't a matter of life and death. It's much more important than that!
