07-29-2011
Iroquois MkII
Using filler to thicken is bad - that has no structural strength. I use woven roving, that's fairly thick to begin with, and then after everything is cured I sand down the high spots, fill with fairing compound (epoxy + microballoons), wait for cure, sand & fill with fairing compound a second time, and then after that cures I paint the whole thing with epoxy, feathering with the brush at the edges (since microballoons will absorb water it's best to seal it). Then a final light sand & paint. If you use West system, you have to wash away the amine blush between each step too, but I use no-blush epoxies.
