leak from engine raw water siphon break - SailNet Community
Blogs
Old 08-10-2003
i670684 is on a distinguished road
I noticed recently a slight trickle of sea water from the direction of
the siphon break in the raw water line. Today I was able to
disconnect the mount from under the sink and pull intact the siphon
break and both hoses out where I could see what''s happening. When the
engine is running there is a continuous flow (more than a drip but not
much more) of water coming out the actual siphon break itself. I
would think the only way this would happen is if there were a blockage
of some type "downstream" of the break. FYI, there''s plenty of water
coming out the exhaust and the engine runs relatively cool. I
disconnected both hoses and did not see any scale or build-up, and the
siphon break fitting itself is clear.
Any thoughts on why this is happening? It has not always been this
way, as the drip falls onto the engine and evaporates, leaving a
clearly visible salt residue that''s a recent happening.
Old 08-10-2003
ARCA is on a distinguished road
I had the same problem with the siphon break on my generator. The break was a Vetus siphon break. The problem was that the ball that is pushed up when the exhaust water is flowing freely had jammed allowing much of the exhaust water to flow through the "overflow" rather than through the exhaust. Although there appeared to be plenty of water going overside through the exhaust water outlet the generator overheated after running for some time.
Have a good look at the "divert" mechanism in the siphon break and make sure it is operating freely.
Lood luck,
Robin.
Old 08-11-2003
Thanks for the idea, Robin. I guess I had a naive view of what''s inside the siphon break itself and didn''t even consider it could be the problem. Funny how assumptions cloud one''s mind when solving a problem. I''ll dismantle it and have a look at the mechanism.
thanks
Windward performance deseely General Discussion (sailing related) 16 01-28-2010 07:16 PM
Siphon break question graham1 Gear & Maintenance 2 11-12-2003 07:13 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 06:59 PM
Cat30 Exhaust riser blew up - Engine won''t start E_N_Z_O Gear & Maintenance 2 07-31-2001 07:55 PM
Raw Water in Engine wmwtlw Gear & Maintenance 3 02-25-2001 12:31 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
