Old 08-01-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
Lifeline upgrade
Is it possible (reasonable) to make a modification to my single lifeline to add another line to make it a double? I really don't want to buy all new stantions.
Old 08-01-2011
CaptainForce's Avatar
I assume you're suggesting keeping the same stanchion heigth and drilling the pipes or putting a collar on the existing stanchions. It seems to me that I remember Schaeffer had a piece that could be tensioned onto an existing stanchoin like a collar with a fairlead to run a lifeline.
Old 08-01-2011
Plumbean is on a distinguished road
This is the product that Schaefer makes: Schaefer Marine Hardware - Detail
I have them on my boat. Work fine. Way expensive for what they are, I think, but they are solid.
Old 08-01-2011
Frogwatch is on a distinguished road
Instead of running another lower lifeline, why not add 1/4" nylon line crisscross fashion between the stanchions from each stanchion to the toerail. Use a continuous piece of line running from stanchion to toerail and back up to stanchion etc. This would give more probability of catching you if you were to slip. OTOH, a good SHORT tether is better. If you are on the port side, attach to the starboard jackline and vice versa. You might also want to simply use lifeline netting and a tether system.
My 28' S2 has only single lifelines and I considered adding lower ones but decided other netting and tether was actually safer.
Old 08-02-2011
nickmerc's Avatar
nickmerc is on a distinguished road
I have the same thing as Plum on my boat. The PO installed and they work great.
Nick
S/V Blue Bayou
1974 Pearson 30 #517
Old 08-02-2011
Barquito's Avatar
Barquito
That is a good idea. I was thinking about adding netting all the way around to keep my dog onboard.
Lifeline project jrd22 Gear & Maintenance 3 02-16-2010 02:32 PM
Lifeline stanchions wungout Gear & Maintenance 14 11-09-2009 08:44 AM
Lifeline Material, SS only? Lancer28 Gear & Maintenance 7 09-06-2007 10:08 PM
Lifeline netting... scurvy Seamanship 17 07-20-2007 08:01 AM
lifeline stanchions bernie-t Gear & Maintenance 4 02-03-2001 12:46 PM
