Old 08-01-2011
grinfax is on a distinguished road
Rusty propeller shaft bracket
Oh wise Sailnet community,
I attached a photo of what's holding my propeller shaft bracket. As you can see the bolts holding my propeller shaft bracket do not look as amazing as they should. The stern port bold is heavily corroded and is leaking just a tiny bit. I need to fix this.
1)Do I need to pull the boat out to make this repair?
2)What is the best way to pull out these heavily corroded nuts?
3)Any other tips on how I should tackle this?
-Kim
  #2
Old 08-01-2011
mitiempo's Avatar
The p bracket is probably bronze but the bolts certainly were not. I would suggest a haulout is the only way to fix it properly.
Brian
You may post attachments
You may edit your posts
Winterizing propeller shaft seal pkats Gear & Maintenance 11 11-03-2009 11:14 PM
Propeller Shaft Packing Material mightyhorton Passport 0 12-07-2008 11:04 AM
Propeller Shaft "Flaking" tcase10 Gear & Maintenance 6 08-02-2008 12:02 PM
Propeller shaft woes............. clayjay Gear & Maintenance 24 03-13-2008 08:17 PM
Uncovered my Newport 27 propeller shaft support, now what? ChicagoNewport27 Newport 2 04-22-2007 12:12 PM
SEO by vBSEO 3.6.1
