Like Tree1Likes
  • 1 Post By sailingfool
Old 08-01-2011
johnnyandjebus's Avatar
johnnyandjebus is on a distinguished road
proper knot to tie a flag to the back stay
Hello all
Can anyone suggest a proper knot to tie a flag to back stay. I know you can buy those spring clip things, but am I bored and looking to learn how to tie a new knot.
Thanks,
John
Old 08-01-2011
fryewe is on a distinguished road
I wouldn't put a flag on the back stay, but if I were to put one there, I would:
Wrap the backstay with black electrical tape at the points I want to tie the flag, then
Tightly rap the backstay with marlin over the electrical tape at the points I want to tie the flag, then
Tie the flag on with buntline hitches.
The tape and marlin should give the small stuff you'll use in tying the flag a bit of softness with friction that will keep the flag attachment points from being blown up or down the backstay. This is the same method that is commonly used to provide a purchase for lashing rattling to shrouds, and gives good enough friction for someone to stand on the rat lines, so it should serve as well for lashing a flag to the backstay.
The buntline hitches should hold the flag in place, but still allow you to untie it when you pull into port. Constrictor knots might hold better, but are almost impossible to untie if pulled up tight. I wouldn't use them because if you have to cut them off, you might cut the wrapping below and have to re-wrap the backstay when you want to put the flag up again.
Old 08-01-2011
sailortjk1's Avatar
I won't suggest a knot, but rather I will suggest one of these. Flag Halyard Kits - Backstay [40-529] - $79.00 : C.S. Johnson, Online Store A Flag Halyard attached to the back-stay will allow you to display, hoist and easily remove your colors.You can part it out if you don't want to spend the money on the complete kit.
Just be careful as the flag can get wrapped around the topping lift and back stay, but it is nice to be able to easily remove the flag, which saves a lot of wear.
Makes displaying your flag very easy, you can practice your knots anytime.
Courtney is My Hero
Old 08-02-2011
ASA and PSIA Instructor
Use two rolling hitches, perhaps best the icicle hitch variation, see Rolling Hitch | How to tie the Rolling Hitch and Tautline Hitch | Boating Knots
Old 08-02-2011
Sailormon6 will become famous soon enough
That's what I use, too, for attaching a class flag for a race. It's secure, and easy to tie and untie.
Old 08-02-2011
Stu Jackson's Avatar
Stu Jackson is on a distinguished road
We have an adjustable backstay and tie our flag onto the backstay. It's a great wind vane, especially going downwind!
Our split backstay has a turnbuckle that I can reach from our perch seat. I tied a small loop of line thru the turnbuckle with a reef knot. The top of the flag has a short line thru its grommet to which is tied a small hook/clip. I clip that onto the loop of line. The line at the bottom grommet of the flag has its own short line which is tied onto the port lower backstay with an overhand knot and two hitches.
Takes just seconds to place and remove the flag.
Stu Jackson, C34, 1986, M25 engine, Rocna 10 (22#)
Old 08-02-2011
Thanks for all of the replies. the rolling hitch looks like it will work quite well.
John
what is this attached to teh back stay?? johnnyandjebus Gear & Maintenance 6 10-04-2009 09:32 PM
back stay tension dvpamenter Gear & Maintenance 2 06-16-2009 08:47 PM
Back Stay Adjustments downeast450 Racing 11 03-31-2009 10:11 PM
Catalina 22 back stay northoceanbeach Gear & Maintenance 4 09-07-2008 12:08 AM
Back Stay Adjustment tdw Gear & Maintenance 9 11-15-2006 12:41 AM
