Old 08-02-2011
wsgodlewski is on a distinguished road
Volvo Penta MD11C engine (oil pressure)
I am new to this forum. I have a Volvo Penta MD11C engine. The engine started to leak warm water. Looking over the engine I noticed that the gear box oil has a whitish color to it as if water was mixed with the oil. The engine oil was normal color and level. The most recent trip the oil pressure dropped to zero and after checking the oil level I noticed that the oil level was none. The dip stick showed a trace of oil on the bottom of the dip stick (color was normal, no water in the oil). Does anyone have any experience with this type of an issue?
Old 08-02-2011
ccher is on a distinguished road
I had an MD11C in my Pelle Petterson (now sold). Thought it generally a great engine but with over 2000 hours it had some issues now and again. Never refused to start however. As to the apparent water in the trans the seals may need replacing. I had what appeared to be a similar problem plus the trans leaked oil and new seals fixed it. As to the oil pressure, probably a gasket somewher-presumably your bilge is full of oil? clean the engine, put in oil, run and look for the leak-oil pan (hope not unless the bilge is really deep), heads, filter on tight? Shut down if no pressure thoguh. You should be able to see a leak. Water leak: same thing, lokk at all hoses and connections, heat exchanger gasket, thermostat. freeze plugs, etc. Let us know what you find.
Flyaway
Cranes Creek, VA
Old 08-03-2011
Thanks for the replay, I will try what you have suggested.
Volvo Penta MD11C for sale CarlsonM54 Sabre 11 09-20-2011 01:03 PM
Volvo Penta MD11C Connecting Rod Bolts Breaking shieek Diesel Engine Forum 4 05-04-2010 08:52 PM
Volvo Penta Marine Diesel MD11C Parts Source? ntheyer General Discussion (sailing related) 35 04-07-2010 02:33 PM
Volvo Penta MD 7A high oil pressure? waterrat2 Diesel Engine Forum 4 10-15-2009 03:22 AM
Volvo Penta engine rondezvous Gear & Maintenance 1 09-24-2006 12:24 PM
