08-05-2011
Courtney the Dancer
First, why do you need to drill such a large hole right next to your mast base for a couple of smallish wires? Second, if your deck is cored in that area you should definitely grind out a bit of the core and fill with thickened epoxy. It's not a hard or long job to do. I use a 1/8" allen wrench in a drill (I grind the short side of the wrench off so it's about 3/8" long for large holes). Only takes a minute to grind the balsa out, vacuum out the chips, then duct tape the bottom of the hole and fill with thickened epoxy. When set up drill your hole thru the epoxy.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
