Old Keel bolt repair - Page 4 - SailNet Community
 1Likes
post #31 of 35 Old 11-01-2011
Senior Moment Member
SloopJonB's Avatar
Originally Posted by alanr77 View Post
HelloS: Catalina direct is now selling a "kit"..albeit a high priced one that requires only a hand drill. I can't see how this could drill a straight hole however without building a guide. I may create a homemade "press" to attach my drill to.
Just drill through a block of wood first, preferably in a drill press, then clamp it down so the hole is over the spot you want to drill. By the time your drill has bottomed out on the block the hole will be deep enough in the keel to keep things straight after removing the block.
Clamping it down is usually the easier said than done part of this procedure.
SloopJonB is offline
post #32 of 35 Old 11-01-2011
SloopJonB's Avatar
Originally Posted by SailingWebGuy View Post
There were actually two layers of plywood separated by REALLY hard grey material. It's harder than concrete although it looks a lot like it. I tried a ton of different tools to remove the grey stuff. Nothing worked well. I ended up having to beat it out with a hammer and wood chisel...took forever. There was another layer of the grey material below the second layer of plywood. Then finally fiberglass and lead below that. In all, I ended up cutting out about 4 to five inches of keel stub.
I`d bet that hard grey stuff was asbestos & resin. It was a very popular filler back then. Diamond hard after curing if it was mixed thick.
FYI - The lag bolts were extremely difficult to install in the 27/64" hole. My pneumatic impact gun couldn't drive them down. I had to bore out the holes a tiny bit. Still couldn't get them in all the way. I finally borrowed a massive Dewalt impact gun and it even struggled with one of the lag bolts.
When doing a job like this I always use a machinists caliper to check the minor diameter of the thread I am drilling for. Galvanizing has big variations in thickness and I drill for what I actually have in my hand. For example, Catalina might have come up with their recommendation by using electro-galvanized bolts which have a thin, almost shiny coating but if you were to use hot dipped, they would have the usual thick, somewhat coarse finish and would far prefer a slightly bigger hole.
Considering what materials you are working with, I`d be reluctant to use anything other than a long breaker bar to turn the socket. You SHOULD be able to run them in by hand. Using a 500 Ft. Lb. impact gun seems to me to be asking for something to strip or shear off. You ain`t bolting a bridge together.
post #33 of 35 Old 11-01-2011
SailingWebGuy's Avatar
Originally Posted by hellosailor View Post
I wouldn't try to install lag bolts of that size with a drill. A nice whopping big ratchet or other wrench, with the longest handle you can find, or a length of pipe added to exend the handle. Torque! Nothing beats it.
I tried that too.
My complete refit is taking completely too long!
SailingWebGuy is offline
post #34 of 35 Old 11-01-2011
SloopJonB
Used stainless lags.
post #35 of 35 Old 11-05-2011
Hey folks.
So I have started to cut out the material and pulled all the wood out. I am now down to a layer of light brown material. It looks like resin and thickener.
Should I continue to dig down to fiberglass?
How far down should I expect to dig before I hit fiberglass bottom of the hull?
Or should I stop here and start the repair IAW Catalina diagram?
Edward
Edcat30 is offline
Encapsulated or Bolt On Keel? aasault Boat Review and Purchase Forum 51 03-26-2017 11:16 PM
25' Catalina Keel Bolt tklinck C25 and 250 2 09-10-2011 12:10 PM
CAL 20 Keel bolt replacement Calabego Cal 1 12-21-2008 04:24 PM
Cal 20 Keel Bolt Issue sailorlinus Cal 3 11-12-2008 04:48 PM
Keel Bolt, Mirage 30 PegasusX Gear & Maintenance 0 09-05-2006 06:48 PM
