Old 08-07-2011
tireman is on a distinguished road
Unknown sail control
I recently purchases a jeanneau sailboat which comes with technique voile brand sails. The genoa has two controls with which I was unfamiliar. I now understand the purpose of the leach line but only today realized that there is also what I will call a footline for lack of a better term. It is a cord running from the tack to the clew and is set up to apply tension along the foot of the sail. But why would I want to? Obviously from the question I am quite new to sailing.
Old 08-07-2011
Mormandeus is on a distinguished road
Hi
The foot line is just like the leech line. If you develope a flutter in the foot of the genny just snug up the foot line to make it go away. That simple.
Old 08-07-2011
I only wondered because I never have had problem with the foot puffing. Why not just tighten up the jib sheet or adjust the jib sheet car
Old 08-07-2011
wescarroll is on a distinguished road
It is to belly the sail in light wind conditions.
Old 08-08-2011
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
The "foot line" is known as a flattening reef and should be tightened in heavy air to flatten the sail. In very light air it should be completely free to add depth to the sail as previously noted, above.
Old 08-08-2011
Liquorice's Avatar
Liquorice is on a distinguished road
Assuming the sail is adjusted correctly to start with, if you tighten the sheet or adjust the car, you'll take it out of adjustment. Adjust to the tel-tales then tweak the leech and foot lines if necessary.
sam :-)
Just because you're paranoid ...doesn't mean they're not after you!
Old 08-08-2011
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
Can you show a picture of this? I don't think I understand what you're saying. That a small (1/8") line running along the foot of a sail is going to flatten it with no mechanical advantage, and then terminate to a light duty v-cleat at the clew seems strange to me.
I'm thinking foot line and flattening reef are 2 separate things.
Merit 25 # 764 "Audrey"
Old 08-08-2011
overbored's Avatar
overbored is on a distinguished road
LEECH LINES AND LONGEVITY - UK-Halsey Sails
Hears an explination of the leach line which is the same for a foot line.
"FULL TILT" SOVEREL 33
"GOLD RUSH" PRINDLE 16
What's this sail control tireman Gear & Maintenance 7 06-21-2011 06:50 PM
Sail Control Updates to an Orion 27 LittleWingCA Pacific Seacraft 1 04-28-2009 12:42 AM
Sail Control Duke 7184 Gear & Maintenance 3 06-13-2007 08:23 PM
Unknown lines & sail questions jmunson2 Gear & Maintenance 23 09-10-2006 09:28 AM
Leading Sail Control Lines Aft Sue & Larry Gear and Maintenance Articles 0 08-11-2003 08:00 PM
