08-14-2011
Originally Posted by aeventyr60
The last time I checked the largest Kyocera was a 130 Watt. It is a real monster. Also the panels put out way more then 12V, hence the need for a good quality solar controller. I use the Sunsaver 20, which also has connections for wind power as well. As others have said "Fuses'! I prefer a high quality breaker, the inline fuse are too lightly wired and the connections are poorly made inside the fuse casing.
I just installed a 210 watt Kyocera on a customers boat a few weeks ago. Used a Blue Sky 1524iX MPPT controller to make good use of the excess voltage. The 1524iX is nice as it automatically detects system voltage and works on 12V or 24V systems. The 210W is a 24 volt panel but that just means more amps when running it of an MPPT on a 12V system.. Customer had plenty of davit space for the 210W panel..
______
-Maine Sail / CS-36T
