Buying Solar Panel - SailNet Community
 1Likes
post #1 of 32 Old 08-08-2011 Thread Starter
Question Buying Solar Panel
I am in the market to purchase a solar panel but I find the choices and specifications confusing. My needs are simple I have a 30 ft S-2 Sailboat
inboard diesel and two batteries which operate the usual lights, small fan, radio and possibly a DC cooler. I want the correct size panel to keep the batteries charged to operate these items when the engine is not running and keep the batteries trickled charged when the boat is not being used for several months. Any suggestions with brand name, model and/or specifications I should be looking for to purchase this item. Thank you calmharbor
calmharbor is offline
post #2 of 32 Old 08-08-2011
TQA
Bombay Explorer 44
TQA's Avatar
Do an accurate energy budget for your longest sailing period and come back with the results. EG so many amp hours a day.
Your question can not be answered at the moment.
TQA is online now
post #3 of 32 Old 08-09-2011
talbot's Avatar
TQA makes a good point about starting with your amp/hr usage estimates. In figuring out the solution, remember that usable amps will be less then the rating on the label. I've been told that cutting it in half is a good estimate to be conservative. Solar panels rarely put out the rated power.
I tackled this project on my boat from a different angle - buy as much solar as your budget or available space allows. You really can't have too much. Put a regulator in line if connecting directly to the batteries so you can't overcharge, or wire it through the battery switch so it's only charging when you are on board.
You can purchase the solid panels and mount them on swiveling brackets for a maximum amps per square inch installation. Or you can purchase soft panels and put them on your cabin top or bimini for a more 'set it and forget it' type of installation. This was my choice. I've checked the output a few times, never when the sun was at an optimal angle. The panels put out 30-60% of their rated power. They are very thin, just glued to the cabin top and you can walk on them without damaging anything. I also prefer the aesthetics as they virtually disappear lying flat.
talbot is offline
post #4 of 32 Old 08-10-2011
calm, in order to keep the batteries topped up when not in use you don't need much power. Something likely 30mAH per battery per day, so one or two (keeping things separate, one to each battery, is a simple robust way to go) small 10W panels would do that job.
Keeping the batteries charged when you are using the boat is something entirely different. Yes, an energy budget is the right way to do it. But in practice I've never heard of anyone being able to afford more panel than they could really use, and following that logic you just buy as much panel as you can reasonably install on the boat. On a 30' boat that might be one or two 2x3 panels. Finding a place to install it (or them) where it won't be shaded or stepped on is the big trick.
At that point you work the other way: Buy the panel you can afford and accomodate, then deal with that much power as being all you're going to get. Switching to LED lighting and running lights (if you sail much at night) can be a very cost-effective way to stretch your power budget, despite the high cost of them. Cheaper than adding power sources, fuel, or batteries.
hellosailor is offline
post #5 of 32 Old 08-11-2011
aeventyr60's Avatar
Have had Kyocera panels on the boat for 12 years. Still full output. Robust panels for the cruiser. Pay proper attention to your wire size and the integrity of your connections. You may want to start out with one panel at first of say 60-80 watts for your initial needs. If you add a DC refrigerator then your talking a considerable amount of wattage, say 300+.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is online now
post #6 of 32 Old 08-11-2011
Irrationally Exuberant
My needs are simple... and possibly a DC cooler.
DC refrigeration changes things considerably--not so simple. Up until that point you're talking using pretty much any 10 - 20w panel to keep the batteries topped up. I suspect you'll need more than 10 times the wattage for that "possibility". Best to figure that out first.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #7 of 32 Old 08-11-2011
casey1999's Avatar
I have solar panels on my boat (PO installed). My question is there a fire danger from the wire from panel to the battery charger regulator? Say my panels are 60watt and the feed wire shorts, seems like it could start a fire in the wiring, or are the panels self limiting on short circuit?
casey1999 is offline
post #8 of 32 Old 08-11-2011
Stu Jackson's Avatar
Originally Posted by talbot View Post
...or wire it through the battery switch so it's only charging when you are on board.
That's the LAST thing you want to do. Wire it to the house bank with a controller. It'll do a LOT of work when you're not there.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #9 of 32 Old 08-11-2011
That's why they invented fuses.
post #10 of 32 Old 08-11-2011
mitiempo's Avatar
Stu beat me to it - Fuses.
SailingChuppy likes this.
Brian
mitiempo is online now
solar panel QuickMick Gear & Maintenance 15 01-18-2016 04:36 PM
solar panel alan_21_us Gear & Maintenance 12 07-31-2008 10:18 PM
B32 & Solar Panel Dcneuro Bristol 2 07-26-2007 10:56 AM
solar panel maestro Gear & Maintenance 3 11-20-2002 11:02 AM
Solar panel ldbarker Gear & Maintenance 3 10-27-2002 01:31 PM
