Blower needed for inboard diesel? - Page 2 - SailNet Community
post #11 of 22 Old 08-17-2011
Dock
The CG Auxiliary does not get paid, they do it as a public service. In general the CG and many local authorities will be less inclined to board if they see the sticker, though it is not an absolute free pass.
tweitz is offline
post #12 of 22 Old 08-17-2011
The most female moderator
Donna_F's Avatar
Dock
Originally Posted by JimMcGee View Post
Definitely worth doing, and I've ben told if you have the sticker on your mast the Coast Guard will bypass you for on-water inspections. Not sure if this is true...
Jim
Not true. It only says that at the time that you had the courtesy inspection done, you had all of the required legal equipment. At the very least it tells LE that you were informed of the requirements.
There's nothing stopping you from removing any of the safety equipment once we leave your boat, which is why a boater should not count on not being boarded.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #13 of 22 Old 08-18-2011
Crotchety Old Member
tomperanteau's Avatar
Best to be in compliance. The Constitution is suspended once you board your boat and the CG or port police can stop you and board you anytime.
We were boarded once by the port police and they never gave us a reason, but they did "ask" to see all the safety equipment that we had and inspected our registration. They were not polite and had a very aggressive posture. For what reason, I don't know. We are grandparents that had taken two children out that both had life jackets on. We were in compliance on everything they checked and they issued no warnings.
I don't judge them all by the bad apples that stopped us, but there are those that are "hot dogs". A few of those rammed into a pleasure boat at full throttle last year, killing a child on the pleasure boat. I think they were court martialed for it.
Capt'n Tom Living Aboard 50/50
S/V Footprints
Youtube
1976 41' Morgan Out Island Sloop. Refitting and redoing her interior for an extended voyage.
tomperanteau is offline
post #14 of 22 Old 08-18-2011
Mark, the most powerful bombs in the US non-nuclear arsenal are "hyperbaric" bombs, aka "fuel air" bombs. Based on a finely atomized spray of diesel fuel. And then there's ANFO, a favorite of terrorists, also built on diesel fuel.
So while blowers are not required in diesel systems, and diesel is damned reluctant to explode, it can and does make a nice fine explosion if you have a high pressure leak spraying finely atomized diesel fuel in just the wrong way. Some folks say a blower should be used with diesel anyway, just in case.
A blower also will help to cool down a diesel engine after you shut it down, which will also help cool down the whole boat faster on a hot summer afternoon, and help keep the oil in the engine from cooking after shut-down.
So, not necessary, but not entirely wasted either.
hellosailor is offline
post #15 of 22 Old 08-18-2011
The courtesy inspection can be done by either the CG Aux or Power Squadron. I usually use the Power Squadron. Does the sticker help you from being boarded...maybe, maybe not, but sure can't hurt to have one.
The inspectors don't just look at your boat, but use the inspection to start a dialog about boating safety and answer questions. I highly recommend everyone to get an inspection. Well worth the time and effort.
chuck53 is online now
post #16 of 22 Old 08-18-2011
Donna_F's Avatar
Dock
I wasn't sure if USPS did them as well, or I would have mentioned them. Thanks!
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #17 of 22 Old 08-18-2011
I have heard of installing them on diesels
So when you get where you are going on a hot windless day, you can blow the hot air out of the engine compartment. Supposedly really helps cool the boat down.
branmiller is offline
post #18 of 22 Old 08-19-2011
CaptainForce's Avatar
I keep two blowers in my diesel engine compartment. One is a large "squirrel cage" dedicated to the operation of my generator to assure CO fumes don't collect,- another big issue. Over my propulsion engine I run a little plastic $25 exhaust fan. These plastic fans last about five years; therefore, I could use them for fifty years before the cost would match the price of the big "squirrel cage". Take care and joy, Aythya crew
CaptainForce is offline
post #19 of 22 Old 09-21-2011
Blower is required, by certain rules
This spring I got a 2004 Catalina 36 and had it surveyed. The surveyor was checking to see if the blower was working and I stated my surprise that it even existed on a diesel. I have never noticed one before and have never used them. He said that it was a requirement by certain yacht building rules so the later model boats included them, but nobody ever used them because diesel boats don't have a habit of blowing up like the old gas ones did.
Engine compartment blower switch is a discrete little toggle switch on the bottom of the engine control pod. I've chartered similar boats in the past and never noticed it.
GJ
SailingJackson is offline
post #20 of 22 Old 09-21-2011
mitiempo's Avatar
It is not a requirement on a diesel powered boat.
Brian
mitiempo is offline
Inboard automatic start up diesel generator evasion General Discussion (sailing related) 11 11-29-2010 08:21 AM
Classic style 17-22ft with diesel inboard james156733 Boat Review and Purchase Forum 7 03-20-2010 07:22 AM
Diesel engine blower? sailor25b Gear & Maintenance 27 04-01-2007 03:08 PM
Blower for Diesel tjohnsonr33 Gear & Maintenance 5 02-20-2007 07:27 PM
Winterizing Inboard Diesel offline2004 Gear & Maintenance 3 10-03-2006 08:52 AM
