-   -   painting anodized aluminum (http://www.sailnet.com/forums/gear-maintenance/7738-painting-anodized-aluminum.html)
mroskothen 08-13-2003 02:11 PM
It seems like in order to paint an aluminum mast one has to sand it blank and then apply etcher -> primer -> paint.
Today I started sanding my traveler and the anodized surface is VERY tough. I used 80 grit and not much came off. Then I used my grinder a little bit and I got down to the blank aluminum. Grinding my traveler and eventually my mast seems a bit too much. Has anyone experience with painting anodized aluminum? How do you get rid of the anodized layer?
The traveler is not painted, just anodized.
Thanks, Markus
GordMay 08-13-2003 02:51 PM
Don''t remove anodizing, just prime or etch it with Zinc Chromate (''green'' outdrive primer) or Oxalic Acid (Aluminum ''brightener'').
Gord
SEO by vBSEO 3.6.1
