Old 08-09-2011
Pub911 is on a distinguished road
Ball-squeezing can't be the only answer.
I've got a Universal M4-30 diesel with an intermittent issue where after a few hours of running under load, it shuts down due to lack of fuel. All the obvious ideas (obvious to me anyway) I've tried: cleaning fuel tank, replacing all the diesel, clearing fuel vent in the tank, clearing all the fuel lines, changing all filters, changing all fuel supply hoses, cleaning the lift pump, changing the 'lift pump' - heck I've even installed a squeeze-ball style inline pump-ball (like for an outboard) in line ahead of the lift pump. And that actually alleviates the issue temporarily. But unless i send crew below to squeeze that ball, she'll stall in anywhere from a few minutes to as much as 30 minutes. I'm baffled - no pun intended.
Out of desperation, I've got a new lift pump coming in the mail that I intend to place in-line where the pump-ball is. I'm thinking this won't fix the real problem, but it may save my crew (and wife) from strangling me every time I scream: "SQUEEZE the BALL!!!.
Can you help me figure this out - or at least figure out what to try next?
Thanks.
Old 08-09-2011
PaulfromNWOnt's Avatar
PaulfromNWOnt is on a distinguished road
Check the lines themselves. It sounds like she's sucking air.
Old 08-09-2011
Gary M's Avatar
Gary M is on a distinguished road
Yep I agree likely an air leak.
Good luck
Old 08-09-2011
pk5352 is on a distinguished road
Interesting. I have and M4-30A in my Catalina 30 and had a similar issue 2 weeks ago. After about 45-60 minutes of running under load, the engine just shut down just as I was entering the tightest part of the inlet to my marina. Tried to restart but got really slow turnover- as if the battery were dead/dying. Managed to unfurl the jib, turn the boat around and get back out to clear water. Let the engine sit for 30 minutes and then she restarted, but with quite a bit more throttle than has typically been necessary.
Interested in the responses here...
Old 08-09-2011
Irrationally Exuberant
arf145 is on a distinguished road
When my Yanmar would run for a while and then quit, it had a small air leak between the tank and the lift pump. If those lines are old, I'd replace them. And I'd check any fuel filter on the suction side.
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 08-09-2011
Thanks for the ideas! I think I'll just replace the filter (it's an old Racor 200 with a 2-micron cylindrical filter element. The filter element is replaced regularly with no affect on the problem, but the filter unit itself has been on the boat since at least '93. I've replaced the o-rings, but never felt great about the fit or my skills on that job.
Old 08-09-2011
mitiempo's Avatar
The other possibility is that some manufacturers installed a screen in the tank on the end of the pickup tube. There should not be a screen there as the crud should be caught by the filter which is much easier to access. I know some Catalinas had this "feature" but not sure which other boats might have it.
As posted above air in the line is also a possibility.
Brian
Old 08-10-2011
celenoglu's Avatar
celenoglu is on a distinguished road
If your tank is well below your engine, the suction f pumps might cause voids (vacuum) in the system. this is very similiar to air in the wystem. Instead of differnt gasesfrom the fuel might fill the gaps or it might be pure vacuum.
Old 08-10-2011
treilley's Avatar
treilley is on a distinguished road
Your fuel pump may have an integrated fuel filter. If you have a small cylindrical pump about the size of a RedBull can, look to see if the bottom end has a cap that comes off. They can be very difficult to get apart but you should see where it has a slot with a post that retains the cap. There is a very small filter in this pump that can cause the exact problems you are experiencing.
It is very common for folks to overlook this filter as most do not know that it exists.
Tim R.
Living aboard in Portland, Maine
1997 Caliber 40LRC
and
Old 08-10-2011
RobGallagher is on a distinguished road
Try cleaning the fuel tank vent first. Spiders love those things for some reason.
As to the OP, +1 for the leaky fuel line.
Still looking for an answer PBzeer Politics/Religion/War/Government 46 07-17-2011 11:31 AM
GOP probably not the answer RAGNAR Politics/Religion/War/Government 2 02-17-2011 05:53 PM
The answer to strife? knothead Politics/Religion/War/Government 3 01-25-2009 09:25 AM
The answer bestfriend Off Topic 2 05-14-2007 11:34 PM
Squeezing into the busy drinks market (The Scotsman: Business) NewsReader News Feeds 0 05-07-2006 09:15 PM
