Old 08-10-2011
jetdrvr393 is on a distinguished road
Catalina 30 Reefing
Hey All,
We just bought an 86 Catalina 30. The PO never rigged the main to reef, there is 1 reef point and thats it. Our old boat had reef hooks on the goos neck but this doesn't have anything. Any suggestions on a good setup? There is a cheek block on a track on the end of the boom but thats about it. Any suggestions and preferably pictures are appreciated.
Thanks
Old 08-10-2011
Sabreman's Avatar
Sabreman will become famous soon enough
Order a catalog from Schaefer Marine. They have diagrams and all the hardware that you need. Catalinas of that vintage were full of options (my dad bought 3 and I worked for 2 dealers). The base boat was really cheap and virtually everything was an option ("#42. Winch handles in lieu of old sticks - $300"). By the time the boat was rigged, the sailaway price was significantly higher. Thus, virtually every old Catalina was different. Fortunately, Catalina did away with that practice.
Schaefer Marine - Boom Furlers, Jib Furlers, Tuff-Luff, Powerboat Gear, Battslide, Marine Hardware
Sabre 38 "Victoria"
Old 08-10-2011
simpsoned is on a distinguished road
Two things... first of all, check with your local gear supplier and you can get a reefing hook for the mast that you can screw to the mast just above the gooseneck or it will ride in the slot...second, get thee to a sail loft...reefing points can be installed by a COMPETENT sailmaker with little or no problems for you...you will need to decide whether you need two sets or just one...(I have just one at about 1/3rd on my Newport 30 main)...if you use 2 sets, it will probably be at 1/4 and 3/8 from the foot.....depending on the length of the foot, I would recommend at least four points...the reefing cringle on the luff, two or three mid sail, and one at the leech...there is a good diagram on Sailing USA where it talks about mainsail parts...good luck...
Old 08-10-2011
There is already a set of reef points in the main, I'm just wondering the best way on this boat. My old boat had the lines run through the boom and a hook on the gooseneck, this boat has neither.
Old 08-11-2011
olson34 is on a distinguished road
Thumbs up Ask other owners...
Nice thing about having a boat with several thousand sister ships is the modern way to connect with those owners on the 'net.
I did a quick search and found;
International Catalina 30 Association
I betcha that you can log into the group and exchange comments and pictures and get your reefing all figured out -- and probably get other questions answered as well.
We do this kinda stuff (and answer boat loads of other questions) all the time over on the Ericson owners' site.
Regards,
Loren
Old 08-11-2011
DRFerron's Avatar
DRFerron is on a distinguished road
jet,
There is a Catalina 30 Yahoo email list that is extremely active. I believe there is a link to it from the C30 website mentioned above. If you join the email list I'm sure you can have an answer within an hour or so.
My main has two reef points so I don't have the same setup.
Good luck.
Donna
Catalina 30
Rock Hall, MD
Contributing Editor
magazine
There are many who sail but few who are sailors.
- David Seidman The Complete Sailor
Old 08-11-2011
Gladrags1's Avatar
Sailor
Gladrags1 is on a distinguished road
When I had my Catalina 30, she had single line reefing with the reefing line traveling inside the boom. This came standard on my 1996 model boat. But like others have said; Catalina has made many changes over the years so there is quite a bit of variation. Check your boom for blocks fore and aft that would indicate internal lines. If not, your likely going to have to add a hook on the gooseneck and a cheekblock or 2 on the boom. No big deal, really. You can get a hook at any Chandler like West Marine. Which one you get depends upon the setup of the gooseneck.
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Reefing without reefing points Rup Seamanship 29 12-03-2009 04:19 PM
Catalina 30 Keel cracks (not Catalina Smile) Pelham Catalina 5 12-01-2009 10:39 AM
Catalina reefing system RandyBC Sailboat Design and Construction 1 04-10-2008 09:12 PM
