storing reefing lines, not rigged - Page 2 - SailNet Community
 1Likes
post #11 of 16 Old 08-11-2011
GeorgeB's Avatar
I’m pretty old school and like the security of a knot. Besides, on my 34 footer, I run 3/8 inch reefing lines (sta-set) so the weight savings would be minimal unless I went to something like ¼ inch (way to small for my liking!). It has been my experience that conditions rarely deteriorate so rapidly that you would need to go from full hoist to double or triple reef in a couple of hours so why have the 2nd reef reeved all the time where all it is doing is flogging the leach of that tape drive sail? When conditions warrant, I’ll reeve the 2nd reef while still at the dock. For me, it is no big deal to reeve it while under sail. I do it after the first reef is set and the main is trimmed. I have no problem standing on the leeward weather deck and reaching up to tie a knot.
GeorgeB is offline
post #12 of 16 Old 08-12-2011
Mermaid Hunter
SVAuspicious's Avatar
You'd have to be 10 feet tall to reach the second reef cringle 12 feet off the deck AFTER the first reef is in on my boat. It simply isn't realistic to reeve reefing lines on a good-sized offshore boat if the reefs are at all deep.
SVAuspicious is offline
post #13 of 16 Old 08-12-2011
Liquorice's Avatar
Not sure how practical this is, as I've never tried it:
Some time ago I read an article about a reefing setup where the guy had one line and a s/s hook with an eye welded to it.
the hook was lifted to the cringles by putting the eye on a boat hook and dropping the hook into the reefing cringles. That way, only one reefing line; the line doesn't have to be reaved through the cringle; use the same hook and line for each reef!
(there's going to be some flapping of Dacron, I think, when moving from reef 1 to reef 2)
sam :-)
Just because you're paranoid ...doesn't mean they're not after you!
Liquorice is offline
post #14 of 16 Old 08-12-2011
This solution give a 1:1 purchase when reefing, if the winch can handle the load it should work.
Think I whould have tied the first reef in after pulling in, that way the hook will be ready for the next also.
knuterikt is online now
post #15 of 16 Old 08-12-2011
GeorgeB's Avatar
Perhaps I’m not communicating the method Knuterikt and I are using very well. We have a small (1/8 inch Dacron in my case) line that is sewn together with a “pigtail” forming a continuous loop between the reefing cringles. After the first reef is set, we tie the 2nd reefing line to the “pigtail” (my reef lines are finished in a Flemish loop). We then hoist the 2nd reefing line up through the higher cringle like one would hoist a burgee on a flag halyard. We keep “hoisting” until the line is through the 2nd cringle and back down to the boom where we re-tie the line around the boom and are ready to go to the 2nd reef whenever we need to. When in 2nd reef, I can untie my first reef line and use it for my 3rd reef using the same technique. It is pretty simple and easy and takes little more time than it does to read this description. I may be a giant amongst sailnetters, but in real life I’m only six feet which is tall enough to reach my boom and my tag line.
GeorgeB is offline
post #16 of 16 Old 08-14-2011
Cal28's Avatar
ok ... trying to understand this more clearly ...
all I can say is ... pictures please?
"It is only with the heart that one can see rightly; what is essential is invisible to the eye."
Antoine de Saint-Exupery
Cal28 is offline
reefing lines sailingtime Gear & Maintenance 26 07-11-2013 12:22 PM
Do you leave your reefing lines rigged all the time? jarcher Gear & Maintenance 31 07-14-2009 12:08 PM
reefing lines bradfalk Gear & Maintenance 7 04-27-2009 10:59 PM
How attach reefing lines Kick Gear & Maintenance 44 12-05-2008 09:10 AM
Reefing Lines? z1nonlyone Gear & Maintenance 8 04-14-2003 05:37 AM
