Decal Removal - SailNet Community
post #1 of 5 Old 02-15-2001 Thread Starter
TSC
Decal Removal
Does anyone have suggestions for removing a large sun-baked decal located on the side of the cabin-top. It is a manufacturers decal that is all cracked and horrible looking. I have tried over the counter decal removers and they did not even touch it. Tried to scrape, only ended up nicking the gel coat.
Thanks!!
TSC is offline
post #2 of 5 Old 02-15-2001
Decal Removal
Try...mek.....methyl-ethyl ketone. Acetone or adhesive remover...nail polish remover...you''re going to have to polish the dickens out of the cabin side to match the new gel coat hiding under the decal/ maybe the manufacturer will send you a new decal instead....Rev.....maritimetradition.com
munchimike is offline
post #3 of 5 Old 02-16-2001
Decal Removal
Peanutbutter or oven cleaner will also work. If you don''t want to use chemcials, you can goto your local automotive shop and buy a tool that detailers use to remove pin stripes from cars. I believe the tool attaches to a drill and will not harm the gelcoat itself.
hamiam is offline
post #4 of 5 Old 02-16-2001
Decal Removal
i removed the name from my boat with oven cleaner.
eric
kimberlite is offline
post #5 of 5 Old 02-16-2001
Decal Removal
Try heat. Many people remove old names, etc. from the hulls by blasting the area with a high-wattage hair dryer. This softens whatever adhesive was present. A step up would be a standard heat gun. But use these with caution.
BigZ is offline
Name/Paint removal garrettav8or Gear & Maintenance 7 08-06-2004 09:57 AM
Stripping tape removal KenKapt Gear & Maintenance 1 03-12-2004 10:36 AM
varnish removal joseph53p Gear & Maintenance 3 11-29-2003 07:12 AM
Cetol removal? WillS Gear & Maintenance 2 05-17-2002 09:57 AM
Treadmaster removal joseph53p Gear & Maintenance 1 11-16-2001 12:49 PM
