Old 08-13-2011
brokesailor's Avatar
SV Skalliwag #141
brokesailor is on a distinguished road
Radar reflector
How do I attach one of these to the shrouds?
Old 08-13-2011
ereiss is on a distinguished road
If I understood the question, this should help
http://www.davisnet.com/product_docu...52_153_157.pdf
Ed Reiss
Being There
Freedom F38 #154
out of Marion, MA
Old 08-13-2011
CaptainForce's Avatar
The reflector in the photo is missing it's third plane. When all three planes are inserted one of the edges normally has a point to hang the reflector on a line, usually fitted like a flag halyard to a spreader. When suspended, the horizontal plane would have a hole in it for the lifting halyard to pass through and the bottom of the reflector would have an attachment for the other end of the line in order to pull it down.
Old 08-13-2011
SV Skalliwag #141
That explains why I thought I had 3 of them!
Old 08-13-2011
jackdale's Avatar
jackdale will become famous soon enough
Make sure it hangs in the "catch rain" orientation.
Otherwise one plane is useless.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 08-13-2011
There are other options for placement such as on the triatic if you have a split rig.
This is not presented in that well advised "rain catch" position, but I've inquired and been told that I present a big target on my neighbor's radar screens. Take care and joy, Aythya crew
Old 08-13-2011
SV Skalliwag #141
Before I shipped the boat to Maryland on a truck they used to be mounted to the shrouds on the Mizzen Mast. I wanted to mount them the same way but have not figured out how to attach them to the shroud.
Old 08-13-2011
aeventyr60 is on a distinguished road
It looks like it is assembled wrong. The two black tabs should be opposite each other, they have holes in them to run a light line through.....my observation
"Your dreams minus your doubts equals your net worth"
"Life favors the Fearless"
Old 08-13-2011
jackdale's Avatar
When in doubt RTFM
Old 08-14-2011
I just used stainless steel wire to bind the reflector to the shroud.
echomaster radar reflector QuickMick Gear & Maintenance 11 04-23-2010 11:58 AM
Another radar reflector? T37Chef General Discussion (sailing related) 13 03-15-2010 08:01 PM
Do I need a radar reflector? Patbarbeau Gear & Maintenance 61 07-24-2009 04:49 PM
Do I need radar reflector in my situation? FrankLanger Seamanship 43 02-25-2007 04:09 AM
best radar reflector for cruisers hathanger General Discussion (sailing related) 8 09-30-2006 10:39 PM
