Grounding strips - Page 2 - SailNet Community
post #11 of 13 Old 10-28-2011
mitiempo's Avatar
What is the strip attached to besides the thru hull?
Brian
mitiempo is offline
post #12 of 13 Old 10-31-2011
Currently, bounded to all thru hulls, strut, rudder, copper screen in bedded it hull, Icon 120 tuner, and keenwood ts340t radio.
Kwasiemoto is offline
post #13 of 13 Old 10-31-2011
kd3pc's Avatar
You need to do some research...the counterpoise is not meant to be a bonding system or voltage sink for non radio stuff...if you are seeing a spark - there is something amiss..ground loop? or something feeding that tape? Stray current from shore power or mis wired boat near by....
I would not attach it, until you find the source...you are asking for galvanic issues...and damage to electronics...
YMMV, and I am sure others will post...
kd3pc is offline
Grounding Coreyboy18 Electrical Systems 11 05-02-2009 11:21 AM
Effect of grounding. chris_gee Sailboat Design and Construction 14 09-06-2008 06:56 AM
Grounding A/C system dbruce85 Gear & Maintenance 3 03-13-2008 07:55 PM
interior-oak strips evecircleM Gear & Maintenance 2 02-27-2002 07:42 AM
Mast Grounding jmedina General Discussion (sailing related) 3 08-16-2001 01:57 PM
