  #11 (permalink)
Old 08-15-2011
knothead's Avatar
Originally Posted by weephee View Post
Thanks for the replies. I think my problem has been that the shrouds and the stays were never tight enough but they are now. Is the purpose of the pin to stop the turnbuckle from actually turning. If so, the rings wouldn't likely do that unless they are big honking ones which then wouldn't fit in the holes. I thought they were to prevent the threads from being totally unscrewed from the turnbuckle. Please remember that I'm not a long time sailor. Just learning Thanks
Actually, the circular pins do a pretty good job of keeping the turnbuckle from unscrewing. They come in a few different sizes based on the diameter of the turnbuckle stud or t-bolt.
Over the years I have found very few turnbuckles that the rings don't work in.
The thing I like about the rings is that they usually can be used over and over whereas a cotter pin that you have to bend is only good for one or two uses.
Ron Paul 2012
"wikijar"
  #12 (permalink)
Old 08-15-2011
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Correct me if I'm wrong but I have a feeling you misunderstand how the split rings are supposed to be fitted. The ring is supposed to be wound through the hole in the threaded shank of the turnbuckle and around 1/2 the body of the turnbuckle barrel. They don't just go through the hole in the shank like a split pin does.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
  #13 (permalink)
Old 08-16-2011
weephee is on a distinguished road
Turn Buckle Pins
Ok, Now I understand. I was trying to put the pin in the threaded rod only. Dumb. Thanks for the response.
  #14 (permalink)
Old 08-16-2011
cghubbell's Avatar
1977 CS27 ~ Ravat
cghubbell is on a distinguished road
You might want to check out Brian Toss' two videos, "Tuning Your Rig" and "Inspecting Your Rig". They are available from his web site, or you can find them used from Amazon as linked above.
They are worth their weight in gold compared to paying for a rigger. His style is accessible to novices, but technical enough for a seasoned sailor to also pick up knowledge. I just finished watching both, and I think they are absolutely the most useful purchase I've made in learning about rigging.
CS27 #1254 ~ Ravat
Port of Rochester
Lake Ontario
14 mm clevis pins svexodus Gear & Maintenance 4 08-04-2010 06:52 PM
clevis pins MarkCK Gear & Maintenance 13 12-07-2009 09:06 PM
Belaying pins adamowens Pacific Seacraft 5 09-15-2009 08:14 AM
Cotter Pins ccriders Gear & Maintenance 9 06-04-2009 12:56 PM
Turn Buckle Threads aphil138 Gear & Maintenance 9 04-14-2005 11:54 AM
