Old 08-15-2011
Windkiller's Avatar
Windkiller is on a distinguished road
Boom goosenecks! fixed or sliding?
Hello
I'm curious as to opinions on the merits or lack therof of the fixed vs sliding goosenecks(with downhauls)
Most of my boats have had sliding types with downhauls
I was given to understand they give more sail adjustment options
What say you all?
Old 08-15-2011
WanderingStar is on a distinguished road
I agree with you.
Old 08-15-2011
ASA and PSIA Instructor
The sliding gooseneck allows you to tension the luff of the main. by hauling down the gooseneck after raising the main. As boats get larger, a winch is usually provided for this purpose, permitting a fixed gooseneck.
Old 08-15-2011
mitiempo's Avatar
If you have or are planning for a solid vang you need a fixed gooseneck.
Brian
Old 08-15-2011
olson34 is on a distinguished road
Post
Originally Posted by Windkiller View Post
Hello
What say you all?
Sliding goosenecks were common on dinghies and still are to some extent. As boats got larger in the early 70's they became heavier and more difficult to use. Then the racing rules provided a solution, albeit kind of an "unintended consequence" ....
Since judging whether a competitor was cheating with an oversized main out on the course, by sighting in on his black band on the the mast, and, hauling downward harder on the sliding gooseneck would better tension the luff on a main built a bit over-sized.....
The solution was to switch to fixed goosenecks. This solved other non racing problems, too. As boats grew, and sailors were buying 27's and then those huge 30' racer/cruisers (!)....
The heavy booms needed something to keep 'em up there when the main was dropped. Then... roller reefing began to be replaced by more-efficient slab reefing and a fixed attachment point made this much easier.
As to tensioning that luff, that's where the cunningham grommet came in to everyday use. Works fine still, after all these years.
So boats, even large ones with original gear, from the 60's will still be found with a big ol' bronze sliding gooseneck, most have been replaced by now or had their old slider pinned in place.
I'm probably missing some more details, but this is a start.
Best,
LB
Old 08-15-2011
Windkiller's Avatar
Thanks that's qute informative
i have a Danica 16 (NOrdica 16 full keel pocket cruiser)
Somebody had replaced the mast and in doing so put a fixed gooseneck on it...but seemly too high as the boom end wants to hang down and the sail bags out freakishly, So I was considering switching to a sliding unit
Perhaps I'll just consider moving it down
It is a light rig though
Any opinions on that?
Old 08-15-2011
RichH's Avatar
RichH will become famous soon enough
You may simply be not correctly raising your (dacron) mainsail which will 95% of the time result in the conditions you describe, or the mainsail may need a bit of 'adjustment' by a sailmaker.
Here's the 'fix':How to properly RAISE a woven dacron mainsail - SailboatOwners.com
Old 08-15-2011
Windkiller's Avatar
Thanks I'll try that suggestion
I'm heading over to work on her right now
Chrysler C-22 sliding kitchenette l0keman Gear & Maintenance 9 05-28-2011 08:25 PM
DIY sliding outboard mount tmalcolm Gear & Maintenance 7 12-23-2010 03:26 PM
sliding hatch QuickMick Gear & Maintenance 2 02-17-2010 11:16 AM
Sliding Gooseneck SteveA General Discussion (sailing related) 3 04-30-2009 10:46 AM
Sliding hatch question. C27Shockwave Gear & Maintenance 3 12-21-2006 08:17 PM
