Like Tree2Likes
  #11 (permalink)
Old 08-17-2011
BarryL's Avatar
BarryL is on a distinguished road
Hey,
I don't think that gravity alone will work well. I would install a macerator pump on the output of the holding tank to the overboard discharge. When you are in an area will legal dumping of the holding tank it will take only a few minutes to empty the tank.
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
  #12 (permalink)
Old 08-17-2011
treilley's Avatar
treilley is on a distinguished road
Originally Posted by mitiempo View Post
The ideal way to install a gravity drain holding tank is with the deck pumpout fitting directly above the seacock so you can clear a clog easily with a rod from on deck.
That would not work for me as the clog I had was at the output of the tank not at the seacock.
Tim R.
Living aboard in Portland, Maine
1997 Caliber 40LRC
and
  #13 (permalink)
Old 08-17-2011
mitiempo's Avatar
Ideally the deck pumpout fitting goes straight down into the tank and the gravity drain is directly below that vertically to the seacock. A straight line from deck to through hull. They work well especially if not filled with paper or at least if biodegradable paper is used.
Brian
  #14 (permalink)
Old 08-17-2011
malaspina is on a distinguished road
Thanks for all the posts and suggestions! I believe a macerator pump would solve my problem if it could be mounted at or very close to the tank, but if its a few feet downstream I'm worried it might not prevent or clear a blockage from occuring further up. I'll have another look but don't think there's any way to mount a pump close to the tank without major surgery. That may lead me to the electric head option. Thanks again!
  #15 (permalink)
Old 08-18-2011
Minnewaska will become famous soon enough
Something else to consider. Electric macerating heads take substantially more water to flush properly and clear lines. Therefore, they use up space in the tank faster. We have them and wish I had vacu-flush instead. Too expensive to retrofit now.
Jeanneau 54DS
Tags
beneteau 331 , holding tank , macerating head
Convert existing steel freshwater tank to blackwater holding tank? patrickstickler General Discussion (sailing related) 7 09-24-2010 07:55 PM
need ideas for gravity feed diesel tank piav Gear & Maintenance 11 11-13-2009 12:40 AM
Dye in holding tank davidpm Gear & Maintenance 5 09-27-2009 12:05 PM
Holding Tank cvsheppard Pacific Seacraft 1 06-01-2009 10:27 PM
Gravity Running Tank for Engine capecodphyllis Gear & Maintenance 11 01-18-2007 10:29 AM
